UCD 25 watts to 1200 watts using 2 mosfets
HELLO
Hi Kirubakaran
greetings before you attempt making d class amps get a proper core T157-2 OR SIMILAR MATERIAL 2 CORE irs 900 amp i feel very sensitive if proper core is not used try the irs 3000 pcb its working good
has ocp will save your mosfets detex audio has changed pcb layout with a reason DONT try IRS2092 till you have made a few dclass amps its cost in india is about400 rs
warm regards
andrew lebon DONT TRY OTHER CORES
Hi Kirubakaran
warm regards
pls post irs3000 pcb layout.
IRS3000D
RNS CHECK PLS.
D
Deleted member 148505
I integrated the OCP in the bias regulator for IRS900
You just need to put a shunt resistor in the low side of IRS900 and cut the "SD to ground" track in IR2110 IC.
Then connect the "pad-sense" pin between the shunt resistor and lowside mosfet.
Connect the "pad-prot" to SD pin of IR2110.
The OCP is based on IRS2000.
LM311 outputs "low" if overcurrent is detected, then triggers the NE555 to output "high" to the SD pin of IR2110 for n seconds.
  • 12vBiasWithOcp-All(Values).pdf
  • 12vBiasWithOcp-All(Names).pdf
  • BiasWithOCP.pdf
hi all .andrewlebon and exflaco. guys can this ultrafast igbt IRG4PC50U be used in this circuit to give an output of 3kwts ?
