How to stop turn on pop noise in speaker
Administrator
Joined 2007
So basically you could do a RC delay + relay to connect to speaker?
Yes, and it can be very simple. For example a small auxilliary supply is created (of your main transformer) using a single diode and cap. The cap is made small as this will determine how quickly the relay drops out. For the switch on delay the relay is fed from a FET with an R/C delay on the gate. It really is that simple. Just half a dozen common parts and a relay.
Administrator
Joined 2007
Like this (I've taken this from an old thread of mine). The FET (IRF240 type) drives the relay. The cap and resistor on the gate set the on delay. The zener (say 12 volts) just clamps the gate voltage to ensure the FET Vgs rating is never exceeded. The reservoir cap is small (say 47uf). Not shown would be a 1N4148 diode reverse biased across the resistor to the gate. This ensure the timing cap is discharged immediately the power is removed.
