Simplistic NJFET RIAA
diyAudio Chief Moderator
Joined 2002
Hi Ricardo,
here are the values I used :
R4=6,790K
C1=46,94nF
C2=15,080nF
C3=47nF
R14=46,93K
R1=180R
I remembered now I had a couple of 47K Z-Foil 0.1%. So I dug them up. No, they are 47K. Its the UT-61E that shows both 46.93K. The LCR meter when in range 2 & 1kHz (calibrated short and open on its Kelvin leads just before), cycles 46.99K and 47.00K every half a second. My 50000 count DMM shows 46.995K when delta zeroed. Check your R4 again too. Caps at 1kHz they must be measured, cycle ranges manually. R.C. he is gonna pull the sims out instantly, I see it coming.:D
Joined 2002
Range 2, 1kHz remember. Gave me surely smack close to 47.00K on both EQU ser par. Those resistors are laser trimmed to 0.1% 0.2ppm grade if you got them from England. They can not really be 46.93K. They can be 47K +/-47 Ohm max. Its the DMM which is 0.5% plus 10 counts at that range (only 4 digits utilized).
I would also like to mention that big gains in sound quality, sometimes bigger than fancy components on the RIAA, can be gained by clean records!
I can't imagine how I could live so long without a record cleaning machine!
