L'Amp: A simple SIT Amp
Hello,
i have followed closely this nice tread, and is time to build my Simple Sit amp.
First i am planing to try L'amp version, and then Hammond 193 Version.
My question is,
do you think i can use (for economic reasons) hammond 193T instead 193V?
I now they have lower inductance(50mH) and only 2A current. Resistance is quite similar.
http://www.hammondmfg.com/pdf/5c0033.pdf
Of coarse Bias will be 2A Max, or lower.
Someone tried to use 193T?
Do you think 193T could be an option, although less features?
Bit late to the party, but hey ho.
This is my attempt. Vishay thick films instead of lightbulbs as a load and CLC power supply using some 280mH surplus chokes I had. Weights it at a cool 28kg! That's an even worse power/weight ratio than the valve amps I normally build. :eek::D
This is my inductor SIT Mono-Block.
