Bragi, an Asynchronous ES9023 DAC with isolated I2S Input and Alps RK27 Volume pot
A simple board based on the ES9023 DAC running asynchronously with an 50 MHz oscillator
It has isolated I2S inputs, Analog volume control with Alps RK27 Pot.
Bottom layer is a dedicated ground plane with no interruptions.
Should be supplied with 6 VDC, which is regulated down to 5 VDC by LT1763 for use with the ADuM5000 isolated DC-DC Converter powering the isolated I2S inputs and going to the 3 separate 3.3 VDC LT1761 regulators used for powering the ES9023 IC, ADuM3440 digital isolator and the 50 MHz oscillator.
I did a few final touches to the board.
Shortened it 5mm, added a ferrite in the supply line just before the oscillator, put a few more GND vias in the board at critical places, reduced the size of the isolated I2S input ground plane area.
Disabled Account
Joined 2002
Hi the more ES9023 DACs the merrier. I think it will perform better without the RK27 though (or add a simple buffer after it). Please add a bead to the power supply pin of ES9023 too and feed it 3.6 V.
Interesting that you use 10 µF for the charge pump circuit. Did you already build it ?
ES9023 should have no problem with a 20K pot. Adding a ferrite bead to the ES9023 supply is a good idea. 3.6V just gives 2Vrms out instead of 1.9Vrms, no big difference.
Havent built it yet, just designing.
The 10uF between Cn and Cp is not a value that I have fully decided on, it could be lower than that and probably should be.
Disabled Account
Joined 2002
Just try the 3.6 V. You will like it better. The reason for this is not 1.9 versus 2 V.
About the RK27: the ES9023 has no problem with it but you will have a higher output impedance at normal volume. In practice it will be better to use the potentiometer at the receiving end. I have doubts if the RK27 is good enough for this application. My guess is that the DAC will sound better without it but that is easy to try out.
What is IC6 and IC7 ?
IC6 is ADuM3440 digital isolator, isolates the I2S inputs.
IC7 is ADuM5000 isolated DC-DC converter. Provides power to the I2S isolator on the input side.
However, Im revising the design, adding a few ferrites, tweaking the layout and part values.
Gone is IC7, it basically draws way too much current(about 33% efficiency) and according to the datasheet it could put out some nasty switching noise, which I do not want in my circuit.
So now the digital isolator has to be supplied with a separate 3V3 supply on the input side.
Disabled Account
Joined 2002
You might want to use a large cap for the positive supply pin of ES9023. 100 µF or more. If you are going to use connector blocks for the outputs (if only for testing) the pads for those must be moved somewhat to the left or you will have to mount the PCB with only 3 screws ;)
This is the final schematic and layout that was sent to the manufacturer.
Overall, I must say that I am more than satisfied with how it ended up.
Took good care in ensuring an uninterrupted groundplane, good bypassing, decoupling with resistors and ferrites in appropiate places, input connector with 5 ground pins to ensure proper ground connection between source and DAC.
Got it up and running.
Sent a 1kHz sine wave from my PC, through the TE7022 USB to I2S converter and then into the DAC board.
Output from the DAC board? A perfect 1kHz sine wave......
:cool::D
No listening impressions yet since I had no amplifier available at work but I should be getting around to listening to it sometime this week.
Anyway, I am happy that it works.
Pics might be incoming tomorrow.
Crossposting from another thread. :
Got it(Balder) up and running today together with my ES9023 DAC(Bragi).
First impressions are very positive.
Detailed without being bright and plenty of control and power.
Tomorrow I will try it with a pair of cheap Sennheiser HD415 110dB/32 Ohm headphones as well as my "highendish" 96dB/250 Ohm Beyerdynamic DT 880 Pro headphones.
So basically I sound like everything is working as intended.
