A bunch (7 or 8 I think) of unused, new in box, subwoofers from MCM. Part of a home theater project I can no longer fool myself into thinking I will ever get to.
I think $15 each is a good price. I bought them from a diyaudio member but at this point I have no idea what the new price was, nor indeed what I paid for them. Shipping in the largest priority mail flat rate box should be possible for ~$17 each.
If you are in the SF bay area we can probably meet to hand them over in person.
If you want to buy more than one, we can talk about better prices.
MCM Specs:
Designed and manufactured in the USA.
10" Treated Cone Woofer
•Large 35 oz. magnet
•High power handling capability
•Heavy duty poly treated paper cone
•Foam surround
•Vented pole piece Specifications:
•Power capacity: 50W/100W RMS/peak
•Frequency response: 21Hz~3.5KHz
•Fs: 26Hz
•Voice coil diameter: 1.38"
•Impedance:8ohm
•SPL: 89dB (1W/1M) •Qes: 0.35, Qms: 3.6, Qts: 0.35, Vas (liters): 110
•Xmax: 5.0mm
Dimensions: Overall frame diameter: 10.16", cutout: 9.13", Depth: 4.31
Weigth ~7lbs each.
MCM Specs:
•Foam surround
•Fs: 26Hz
•Impedance:8ohm
•Xmax: 5.0mm
Weigth ~7lbs each.
FWIW, they're $19.95 from MCM in quantity < 4 (17.95 for >= 4), so I think you'll have better luck at $10...Boy, you guys are a tough audience; how about $10 each?
http://www.mcmelectronics.com/content/ProductData/Catalog50/section05.pdf
It's in there somewhere... Do a "Find" on 1945 and you'll find it.
Thanks for that, I'd never have guessed to look in the 'paper' catalog.
For what it's worth, you can't actually order one using the 55-1945 part number despite the apparent availability, but I think "new, new, new..." part is pretty funny, perhaps the pdf is old, old, old...
http://www.mcmelectronics.com/content/ProductData/Catalog55/C55.pdf
The fall 2011 pdf has no such entry, so I think they are not really available, well except from me of course ;-)
