Is this new measurement info? Or did I just miss it?
http://meniscusaudio.com/images/NEO8S-spec sheet Rev1.pdf
The frequency response is very interesting if you compare it with the normal Neo 8 and the Neo 10. You can see response irregularities that are similar to the Neo 10's, that don't show up on the Normal Neo 8's. Notice the hiccup at around 5.25khz(Probably due to the thicker metal basket and larger magnets). They also appear to have a much better low end response than the normal Neo 8's.
http://www.zaphaudio.com/temp/B&G-Neo10-FR.gif
http://meniscusaudio.com/images/NEO8.pdf
One thing viewers need to keep in mind is that BG uses graphs with taller vertical divisions(as apposed to squished), compared to most other companies. Reason being is that the graphs are geared mainly towards the professional market..
This one kills me. Free air, with high vertical division. It's almost as if they didn't want people to buy them..
http://meniscusaudio.com/images/Neo10 datasheet & whitepaper.pdf
Are you refering to the graph in the Neo10 spec?
What's the price of the Neo8S, same as the old one? If so, it seems like a better purchase than the Neo10 considering it's half the price and one wouldn't need a separate tweeter, right?
Yes, in post #4, I was referring to the Neo 10 spec. I can't figure out why they didn't put it in a box before measuring it, like they did with the Neo 8-s.
Your right, the Neo 8-s is a great value.
