UCD 25 watts to 1200 watts using 2 mosfets
About Core
Sir, I have these core from old Computer SMPS. the size of core u can see, i wanted to know that can i use it with IRS1500D or for irs900D?
Hi Prasanna
greetings there are no schematics just make pcb put components and enjoy
the sound ONLY if you have the proper core make it otherwise
warm regards
andrew lebon
they will certainly be hot as a soldering gun, but if you have no option, use a hack saw to cut 1mm gap which will atleast help.
the best thing is to use the EE or the EI core from that PC
>>>> coil 24turns,use a piece of old CD to make 1mm gap
refer to previous posts, there're even instructions by other DIYers on how to go about it
