diyAB Amp The "Honey Badger" build thread
Have just tested this amp with a 2pf mica cap installed as an LC cap. This made sound worse than when using no LC cap which it is now reverted too. I found there to be too much high frequency noise with the LC installed. Without it there is more bass and a better rounded sound.
Simon
Just Saying, I think that the "Ostripper" post was not him, maybe the account was hacked...Just Saying
Maybe? His mongrel website which is apparantly current and updated hasn't been available for a while now. Would be nice if someone new him personally and could find out. Maybe he had health issues etc etc. All I know is Ostripper always use to be very prompt at replying to technical questions and always fast to help out anyone in need. Hope your doing well wherever you are OS.
Simon
Maybe. Though that toothy smile emoticon sure carries some sarcasm though. I can't imagine someone hacked his account then knew enough about the amp and his contributions to fake a sarcastic emoticon that well.
I suspect it was him but that there is more going on. Whatever, I hope all is well too.
My HB progress so far..
Mouser Parts
Is there an ETA on getting BOMS with Mouser part #s?
Howabout right now?
For reference, here's a link to the BOM
See if I made the correct selections?
Diodes:
1A Silicon D1, D2
3A Fast Silicon D4, D5, D8, D9
Red LED ~2V D6
Blue LED ~3.5V D7
BJT
MPSA18 Q1, Q2
SC1845 Q3, Q4, Q7, Q8
SA992 Q5, Q6, Q9
SA1381 Q10
SC3503 Q11, Q12, Q13
MJE15032 Q14
MJE15033 Q15
NJW0281 Q16, Q17, Q18
NJW0302 Q19, Q20, Q21
Trimmers:
200R R7
1K R17
500R R30
Metal Film and/or high precision resistors:
100R R8, R9
220R R20, R21
33K R3, R6
1/4w Resistors:
100K R1, R52
820R R2, R5, R22, R24
4.7R R4
22R R10
10K R11, R12
15K R13
2.2K R14, R28
100R R15, R16, R26
22K R18, R51
68K R19
220R R25
680R R29
15R R31
1/2w Resistors:
33R R23
68R R27
22R R32, R33, R34, R35, R53, R54
1w Resistors:
150R R36
2.2R R37, R38, R39, R40, R41, R42
3w Resistor:
10R R49, R50
5w Resistor:
0.22R R43, R44, R45, R46, R47, R48
Capacitors:
4.7uF Signal C1 (Can sub Blackgate or Elna Cerafine//10nF polyester)
270pF Filter C2
220uF Signal C4 (range 220uF to 680uF--size adjusts h1/h2 bass character)
100nF Poly C3, C10, C12, C14, C16, C21
47uF C5
220nF Poly C6
100pF Mica C7
470pF Mica C8
22uF C9
220uF C11, C15
470uF C13, C17
47pF Mica C18, C19
680nF Poly C20
Power supply?
Mouser parts CRC type Power supply, affordable and easily doable on perfboard?
Schematic (C4, C2, C12, C13, C17, C18, R11, R12 not used in economical version)
2 Bridge Rectifiers KBPC2502 (2 pieces of KBPC2502 represents/contains/replaces D1, D2, D3, D4, D5, D6, D7, D8)
3,300uF (Smoothing cap), C1, C3
Safety Drain R9, R10
0.82R (PI Resistor) R1//R2//R3//R4, R5//R6//R7//R8
10,000uF (Big Tank) C5, C7
2,200uF (Small Tank) C14, C15
0.1uF (HF filter) C6, C8
33K (LED current) R20, R21
Safety power indicator LED2, LED3
P.S.
I also made a virtural dual mono post.
diyAudio Editor
Joined 2001
EZ enough on perf,
We do have PSU boards in the store too. Might be out of stock ATM
Seems like on AB amps you don't see the Pi filter arrangement, with the resistors much
Probably because the amp has decent power supply ripple rejection. The resistors lower the voltage a little
and maybe the varying power draw of the AB amps is an issue..
Anyone know?
