Subwoofer controller
I have build this circuit sub woofer controller but not work!! IC1 not work. at pin 7 on IC1 not work, it give -12volt on pin 7, what the problem?
Power supply is +/- 13to 14 volt unregulated IC TL072. please help?
thanks for reply. I have use TL071,actually -12 volt coming from Pin1 on IC1a. and also cheeked another IC LM358 if i separate from IC1a part from IC1b then IC1b part is ok only flloting voltage is cuming from IC1B pin 7
After 2 days investigation i can found an error look carefully IC1a here is marking pin no 2 is non inverting and pin no 3 is inverting input,actually it will be reversed.So as a symbol wise it is ok but pin no wise it is wrong and i made PCB as pin no wise and make positive feed back in IC1a.
