TRIELL IRS2092+TC4420
Do you have an bottom pcb lay out?
TRIELL ,DIGITCLASS
Thanks cheshtap...this is working with out hum? What is the maximum supply and ampere?
try this tri-l
This is working without hum ?
try this tri-l
Hi do you have PCB Layout for this amp ?
here is the original source of 3200w1 r no hum but have Bacon hehehe peace
AMPLIFICADOR DIGITAL DE 3200 WATS 1 OHMS DIRETO NA REDE 127 VOLTS modificado 25 06 2012.rar - 4shared.com - online file sharing and storage - download
but wheres the origin schematic ?
i think it is based on this one below because it is non ucd diysmps
http://www.diysmps.com/forums/showt...e-and-Non-UCD-style-PCB-Ready.-Tested./page15
Hi
I'm kind of new to class D, so how's this?
Fets mount under the board.
supplies for comparator and ir2110 are one separate boards.
I plan on using it as a sub amp (if the board is good...)
also a stupid question, if I use it as a sub amp won't there be bus pumping? and if there is won't full bridge eliminate it?
Thanks in advance! and sorry if I wrote something stupid...
T.C.
T.C.
DUAL LAYER
Why does the layout looks like a class-B amplifier
Irvinejay could you share the inductor 3200 127v schem? the coil air gap inside?
look chestap posted for schematic yes ee core have airgap 1 mm
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
