Burning Amp BA-3
Just another Moderator
Joined 2003
Hi Guys, I need to get some 2sk2013/2sj313's for my BA3 boards before they become unobtainium.
if I can specify the current for matching, what is a desirable current? I've searched the thread but haven't seen any recommendations. I already have the 70/74's matched at 10mA as per Nelsons artcile.
Is the figure for the mosfets less important? should I just ask for two matched pairs that are close together and not worry too much about the absolute value?
Tony.
Joined 2003
I figured if I can get the toshibas then I should. Could just be a case of because Nelson used them everyone assumes that they are best, but I figure if they are what Nelson specced then I can't really go wrong :)
It will probably be quite a while before I actually build it, but I want to secure the parts whilst I still can :)
Tony.
Official Court Jester
Joined 2003
will it drive F4 ?
Hi all!
Somebody in a previous post has asked about mixing and matching ba3 with f5. Has anyone tried that?
If someone (me) tried to use ba3 as a unity gain buffer would the adjustment of the gain resistors ratio suffice or other adjustments have to be made?
What about the input of the ba3 in the above case?
