SSLV1.1 builds & fairy tales
Joined 2009
With 2K dummy load Right channel negative rail
diyAudio Chief Moderator
Joined 2002
Still problematic.
Merlin, do you have 270R for sure in gate stopper place (parallel on board near the input & output Mosfet pins)? Or something different value by any mistake? Some used before heated cap many times with iron? Because you should have simple line like in your positive pic no problem at least with dummy test.
Joined 2009
Still problematic.
Measured all four gate resistors 270R in the negative rail and all four measure 270R, attached pic right channel negative rail
