Hi Wavebourn,
the one that I know sadly doesn't feature plate curves referencing to 300 v screen. But the plate curves herein at pages 2 (top) and p3 (bottom) respectively, surprisingly differ much!
I've also had a look at the EL153 curves, mainly the same tube, but lacking the supressor grid, but also there's none for 300 v screen.
Best regards!
Best regards!
The main problem I have with the GU50 datasheets is the Russian language. I guess Anodespannun is Max Anode voltage, but the rest is a bit of a mystery TBH - so I tend to build, measure, tweak - a bit like fumbling in the dark!
Compared to that the small signal stuff is easy
Hi Wavebourn,
Best regards!
I thought EL152 is the civilian version? See if this one make sense.
Jaz
Check this thread:
http://www.diyaudio.com/forums/tubes-valves/163459-trying-make-sense-sweet-peach.html
There's also some other threads on the GU50 with data, mostly supplied by Wavebourn, who's an expert.
Thanks. I know this sheet. At page 9 we find suitable data for audio frequency amplification, but it doesn't show the requested plate curves @300v screen. Those at p.3 relate to 250 v screen.
Best regards!
In all GU50 datasheets only 250V G2 operation is mentioned. So this means you have to extrapolate them (make them up )
Bilingual datasheet here. Seems like they wanted to make monies off potential enemy, too
http://tubedata.milbert.com/sheets/018/g/GU50.pdf
PDF format did not exist during Cold War.
So, is it the Ukrainians post 90's that made the translation, to sell them easier to HAM's? In any case a fascinating part of history.
- Tubes / Valves
- GU50 plate curves
