Hi,this amp is the same scheme.
Chinese AODA
The origin China Manufacturer is AODA
www.cn-aoda.com
look here
Enping Aoda Electronic Technology Co., Ltd
PRONOMIC = old heavy technology from the past
you get for this much EUR SMPS light weight Class H amps
from LEX
Switching Mode Class H amplifier
German Distributor is available for LEX ....
hi irvynjay and andrewlebon,
pls guide me.
1-when first power up two led's lights on in the driver board,
2-i set dc offset to omv with the 500ohm preset.
3-i set the bias preset to half turn ,
4-protection section working with 12v dc,
-active led is on, when the 12vc power given,
-protection led is on, after relay active the led is off,
-when power off the amp, the clip led is light on and slowly off,
5-i provide signal to the amp, but out signal not comming, what will be the problem?
pls guide me.
Hi Nazirdigi
greetings please check NC/NO relay connections on pcb if i am not sure pcb track has to be cut
warm regards
andrew lebon
Hi andrewlebon,
Thanks for the reply andrewlebon,
i already cut the pin from relay.
here is the new images,
supply voltage 50-100-0-50-100vdc.
So how you solve you problem nazirdigi? am i correct? pre driver need heatsink ,
temprature will increase but its normal
hi irvynejay,
i think one of my mje's bad.
now i feed audio and sound is very good. and no heat on heatsink.
output base voltage is 180mv dc, but emitter resistor across in 0v i adjust the preset but nothing happenning,
thanks ,
About bias
which resistor used to across 5mvdc and any other change in your circuit ?now the amp is working perfect.
dc offset 10mv, i adjust bias emiter resistor to 5mvdc and woks perfect.
hi ravpeet.
.33 5w resistor.
only one change 18k/2w resistor in .33/5w in that place.
- Cheshtap Power Amp
