Joined 2009
need to deside how to place the tweeter
their 3 options
any sugestions are wellcome
With a 1" compression driver you will not have the same treble performance, as with a dedicated supertweeter, like Fostex T500mk II, Coral H-100, TAD TD-703 and alike. I made direct comparisons, supertweeters deliver more transparency, more air, they perform definitively better in the frequency range you intend to cover.
Tad is not an option becouse of price
Fostex when play from 5khZ sounds to bad
Will se what I got with Radian
A friend of mine who made a lot of tests approved Radian the best for my use
Sent from my SGH-T959 using Tapatalk 2
Fountek Neo CD 2.0 is a cheap solution, and seems to perform similar to Beyma TPL-150. Only negative side is its low efficiency.
- 4-way active 15+10+4"horn +tweeter
