Dunlavy 1VA type clone speakers - DanWilson - Speaker Asylum
The speakers use two 10 inch Dynaudio woofers, two 3 inch Dynaudio dome mids and the Dynaudio Esotar tweeter.
Dan,
If you consider that in the context of this forum Full Range = Single Driver, then no, your Dunlavy are not Full Range they MultiWays.
The irony is that there is no full range single driver (full-range multiways are rare too)
FASTs (woofer assisted single drivers) can be truly full range.
dave
dave
Perhaps this forum should be called single driver fullrange....
This forum is for discussing single-driver fullrange designs.......there is also a multi-way forum. You are not the first poster to post a multi-way design here....sometimes a bit confusing.
Pano, if you dont consider these full range then what do you consider full range?
- Full Range
- Dunlavy 1VA type clone speakers
