MOSFET Amplifier IRFP240/IRFP9240
I have few questions about this design:
If I want more or less power i just need to add or remove amplification degree(i'm not sure how it is really named in English.. ) of mosfets?
How can I calculate needed power supply voltage for this amplifier if I remove or add another pair of mosfets?
HV23
This is what i have done up till now...
some more pictures...
Nice work, that will be valuable amplifier, thanks for shareing.
Heh,THANK YOU for sharing all this with us! :)
One thing must be considered,and that is if anyone uses *2N5401/5501 MJE340/350* than must be careful with pin-placements because the pcb was made for *2SA-2SC* combination with BC639/640. BC327-337 that replaces BC639-640 also has a different pin-placement,so be aware...
Some pictures from tonight:
It actually sounded clear all the time at all volume stages.
Now i see that microphone on camera has eaten most of high sounds and that was happening when the amplifier was at loud,when i lowered volume the microphone was able to pick up sound pretty well. Nothing strange,all that sound in a 40 square meters... First time when i get a chance to use it on an open field i will record a new video and than it will be possible to see that the amp does not wreck high sounds. It sounded clear all the time at all volume stages.
