Capacitor Identification Help
:confused: I deperately need to identify these two caps so that I can order another pair for the other channel in my system.
I believe the one numbe that is blurred said 186K.
What is this in mfd? is that 1.86mfd?
Most likely 10µF and 6.8µF/250V, the only unknown is the dielectric.
Probably mylar or polypropylene, but anyway for a Xover it makes very little difference.
They look physically too small to be 10uF/250V.
As already mentioned - why not measure them on a DMM with Capacitive scale.
If they are part of a loudspeaker crossover then the 0.01uF and 0.0068uF would be too small.
Although on one of the capacitors the marking is indistinct, let’s assume that they are marked
106K
ME250
and
685K
ME250
This makes the first one 10µF
The K suffix indicates 10% tolerance
And it should be safe to assume 250v DC working.
Likewise the second sample is 6.8µF, 10%, 250v
I think the dimensions look about right for these values.
The dielectric is not known, but my guess would be polypropylene or polyester film.
I do not recognise the manufacturer’s logo to the right of the value code.
ME probably is the series type allocated by this manufacturer.
