F5 Turbo Circuit Boards
Joined 2010
OK,
Here they are.
PSU Board
SE Input Board
Balanced input board
Single Output Board
F5 V2 Combo Board
V2/V3 Output Board
Guys... What do you think about using the case of this amplifier to build F5T?
It was an amp made around 20 years ago.
It's original specs (don't know how true they were, perhaps a little too pretencious given 950VA power consume on max. signal):
200W RMS @ 8 Ohm
325W RMS @ 4 Ohm
The case dimensions are:
420 x 185 x 430 mm (WxHxD)
PS: The fins are bigger then they appear on the photos. I'm going to measure them myself and post them here.
More photos/specs:
AUDIORAMA - Equipamentos de Audio - NASHVILLE A77is
AUDIORAMA - Equipamentos de Audio - NASHVILLE Amplificador
Thanks!
