Everyone will have their favourites. I always use this which is specially for any combination of plastic/metal. Great on the notorious CDM12xxxx assemblies too.
SPG35SL - ELECTROLUBE - SPECIAL PLASTICS GREASE, 35ML | CPC
Thank You for advice. I will try it.
Regadrs,
f.
Vaselina
Hi
orr.. simple try VASELINA /italian from pharmaci....pure silicon.
Ciao
Cici
Two kinds of muffs - plastic and metal are used in KSS laser units (SONY and replacements). What kinds of lubricants are proper in both cases?
f.
Hi
Ciao
Cici
I trie both silicone grease and silicone oil, and both caused more damage than any good. I think the "muff" is a sintered brass, that soaks oil like any sintered sliding bearing, i.e. self-lubricating. I found the best is to clean the steel slidings with paper tissue and not lubricating it.
