UCD 25 watts to 1200 watts using 2 mosfets
Dimonis... self osc ucd can give 10kw if you want.:D
Make some tests without preamp..use my gain 10 2/3 power divider schematic that i posted a while ago.
absolutely right, CPX can u post again optimum pre-amp for ucd? i want to improve gain with my discrete ucd , wanna see if there is lot improvement with preamp and without it, i`ll report the result here after..
thanks.
Hi all
completed my PCB and waiting T106-2 core,before it comes i wound a T38(i think its T37)yellow white core pls check my photo
manojtm:
What i posted a while ago was a divider for measurering distorsions not a preamplifier schematic.
I do not have a schematic with your requirements but irs2092 cames close to THD 0.07% sometimes if done with 2 transistors only.60db means gain 1000..have you misspelled.:confused:
Use cut ferite core for testing..the yellow white one is disaster for class D..
I am sad to see that you made the board that i said not to do because it is bad...:(
norazmi:
You said in one of your clips you improved THD...how is that..you didn't even measure it..:eek:
