A better enclosure for JBL L100T
Hello Fellas,
I want to build new cabinets for my JBL L100T's. The existing enclosure has the volume of:
~ 36.6 X 86.2 X 29.8 = 94016.6 cm^3 =~ 94.0166 litre
I am going to make the cabinets ported in the front.
I am just wondering whether the existing cabinet volume is best for them, and if there is a better result with another enclosure volume.
The port diameter is 4". What is the optimal length for such a port?
I may use flared port.
Any help will be greatly appreciated.
GM
Joined 2003
Greets!
'Best' is what works best in-room, so no clue what's 'best' for you. Me, I like to have plenty of net volume [Vb] tuned to Fs in this driver's case as it tends to work well when near/at a wall or corner and allows a reasonable amount of tuning flexibility, so based on published specs, a Vb = Vas [~7.9 ft^3] seems reasonable with ~ 0.694x Vas [~5.49 ft^3] being about as small as I would want to go.
Note that a single 4" vent is a bit small for this driver's power rating and I'm guessing why JBL put it on the rear, so I'd want at least a 5" or dual 4".
The optimal length would be whatever tunes the cab to Fs or whatever performs best overall to you in your room.
GM
Greets!
GM
0.694x Vas [~5.49 ft^3] is 3.81 ft^3. This is almost 4 cubic ft!
The internal volume of the existing cabinet is ~ 3.32 cub. ft, which I think it's already a little bit on the "too large" side ... the bass tends to get a little bit loose and too bassi for my taste. I want a little bit more accurate response in the low end.
I haven't seen a frequency response graph of this particular speaker .. but going by the published spec's (35hz @-6db) it looks like the bass response would have a 2db peak just before dropping off quickly. If you'd like a flatter bass response, I think you'd be looking to loose about 1cu.ft. of Vb. (70l with a 39hz tuning).
I'm not an expert though, so take that with a grain of salt.
So, 70 litre internal volume with a 39hz tuning needs a bass port of: 0.102m (diameter) and 0.151m (length). Is that correct?
How about 80 liter cabinet with a 34Hz tuning?
Isn't that a better idea?
Not according to the driver's published specs, which way too often calculates a too small 'ideal' cab to begin with. Just from eyeballing some pictures and reading its marketing blurb, it appears to be tuned fairly high, a typical Altec, JBL alignment that earned them the 'west coast sound' moniker way back when, which would cause it to be a bit 'loose'/'bassy'. As sreten noted, it can be smoothed out by 'critically' damping the vent or you can tune it lower with a longer vent.
If you want more 'tight' bass extension though, you'll need the larger cab tuned down to around/at Fs.
GM
GM
That is not what I meant. Lining the port with foam tunes it
lower, it doesn't "critically" damp the port. The bass will be
"tighter" without needing a larger cabinet. There will be less
of it but the speakers will also go somewhat deeper.
rgds, sreten.
OK. The internal volume of the existing enclosure of the L100T is ~ 94 Liter. The port is 4" in diameter and a little more than 11 cm in length. So, if I am right (and please correct me if I am wrong), the tuning frequency of the enclosure must be: ~ 37 Hz.
Also, these a the parameters of the JBL 2214H woofer:
2214H tech sheet?
(These can be found in JBLPro website too.)
Using WinISD software, here is the Gain plot of 2214H driver in L100T cabinet:
attachment.php
According to this plot, there is a bump around 45.9 Hz. I think this is why the bass gets too "bassi" and sounds a little bit loose with some types of musics.
So, if I am right (and again, please correct me if I am wrong), if somehow I manage to flatten this peak, I have improved the sound.
With 80 liter internal volume, and a 34 Hz tuning, I get this plot:
attachment.php
This is much flatter to me, and it is still 36-37 Hz inside 3db. That's why I suggested this volume and tuning frequency. I think I need a port of 4" in diameter and 18.6 cm long.
I have only considered and compared Gain plots. I don't have the enough knowledge to considered other factors now... I think need some help to get it really right!
