Here my collection over the years from my computer
Fostex FW800N
http://www.fostexspeaker.de/woofer/fwserie/fw800n.pdf
Audio B-Class Lisence
’´’ቹ ƒX�[ƒp�[ƒE�[ƒtƒ@�[ ƒTƒuƒE�[ƒtƒ@�[ ƒz�[ƒ“ƒXƒs�[ƒJ�[ ƒ}ƒ‹ƒ`ƒAƒ“ƒv ‰¡�{‰êŽs
Mitsubishi-Diatone
SubAudio - Diatone - Telechargements de plans d'ébenisterie et schémas d'enceinte - Paramètres des haut-parleurs (80cm und 160cm)
My next subwoofer - Club Polk
MITSUBISHI/DIATONE�@SC, SS, VS series, Center speaker,A subWoofer, others
Der BESTE Subwoofer der WELT!, Subwoofer - HIFI-FORUM
(Photos Mitsubishi and MTX - see post from 19. Okt 2009)
MTX Thunder 1000000
not to find by the MTX website:
MTX Car Audio - JackHammer Subwoofer
O Maior e Mais Potente Subwoofer do Mundo | DSystem News
MTX Thunder 1000000 - Soundmasters Forum
Electro Voice 30W, Fane "Colossus 24 Bass"
http://archives.telex.com/archives/EV/Speakers/EDS/30W EDS.pdf
Lautsprecher, Klassiker Lautsprecher, Lautsprecher Klassiker, audio classics speaker (Photos about ElectroVoice "30-W" und Fane "Colossus 24 Bass")
Clarion SRW 8000
no information about Clarion's website:
Clarion car audio
CLARION SRW 8000 WIE NEU!! (80CM SUBWOOFER) bei eBay.de: Subwoofer (endet 28.02.10 22:30:28 MEZ)
http://www.bilderzumanziehen.de/mercury/P1160110.JPG
Clarion SRW8000 32" Subwoofer Reviews
clarion 32" woofer - Overclock.net - Overclocking.net - Photo Gallery
Magnat aggressor 5000 6000
http://www.magnat.de/fileadmin/user_upload/Produkte/BDA139505.pdf
http://www.magnat.de/fileadmin/user_upload/Produkte/BDA142401_EN.pdf
Magnat Aggressor 5000 DM, Car-Hifi: Subwoofer/Gehäuse - HIFI-FORUM (Seite 2)
Magnat Aggressor 5000 Death Match Brauche Hilfe!, Subwoofer - HIFI-FORUM
Rapid Scan Videos - Download - Magnat videos
YouTube - magnat Aggressor 5000 Deathmatch
Corvette Subwoofer Magnat Aggressor 5000 - Car Videos on StreetFire
[EBAY] 80 cm Riesen Subwoofer - Seite 4 - pagenstecher.de
(photos Magnat Aggressor 6000, Clarion SRW8000)
Kics PW-1001
Kics Datenblatt
::::: KICS CHUNIL :::::
CHUNIL CORP.
Hartley HS-224
http://www.diyaudio.com/forums/mult...e-european-loudspeaker-drivers-ever-made.html
Cabasse 55ND
Cabasse haut-parleur 55ND
home
caisson Cabasse saturn55
Precision Devices PD2450 - good known, highest quality and best available of all - and together with PD-2150 my own favorite
http://www.precision-devices.com/asps/uploads/super/17.pdf
Strassacker: Lautsprecher - Boxen - Selbstbau
audio87
PD2450 - Speakerplans.com Forums - Page 2
ADAM Sub2100
about Fane "Colossus 24 Bass" and an very large bass from Supravox (made for submarine research) I dont find any informations. Perhaps one of you knows more about this and additional other brands.
Fostex FW800N
Mitsubishi-Diatone
MTX Thunder 1000000
Clarion SRW 8000
Clarion car audio
Kics PW-1001
Kics Datenblatt
CHUNIL CORP.
Hartley HS-224
Cabasse 55ND
home
audio87
ADAM Sub2100
..Precision Devices PD2450 - good known, highest quality and best available of all - and together with PD-2150 my own favorite..QUOTE]
Hi tiefbassuebertr,
I wish I had one to play with!
b
Hi tiefbassuebertr, I wish I had one to play with!
b
the PD2450 is optimized for mid class chamber sizes. If you have chamber space available enough, the PD2150 or even the cheap PD186 (more pcs) are clearly to prefer - see photos of two projects from me by post #12 about
http://www.diyaudio.com/forums/subw...orld-milano-full-power-down-10hz-galerie.html
;2138897 said:the PD2450 is optimized for mid class chamber sizes. If you have chamber space available enough, the PD2150 or even the cheap PD186 (more pcs) are clearly to prefer - see photos of two projects from me by post #12 about
Hi tiefbassuebertr,
Are you kidding me
b
No matter what size the diaphram is these woofers can't get around the problem of needing raw cabinet volume for efficiency at very low frequencies. They don't get around the problem of resonant frequency having a strong effect on efficiency either. The cost of these rarities makes the maximum usual coil diamter of 4" and the cone diameter of 18" pretty attractive. After all you may easily end up with lower harmonic distortion with multiple smaller drivers. In other words, huge drivers don't mean ultra-low bass. Only power and cabinet size will get you that, necessarily.
Of course the common "cheat" is excursion capacity, allowing you to get more out of a single driver:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=293-666
But, this doesn't get around the power and Fs problem at all.
Theoretically you could put nothing in your enclosure, as in vacuum. Nothing means nothing, so there would be no limit to how small you could make the box, assuming your driver could fit in it. You'd have to come up with a spring that had very linear force over the excursion range, except for the rate required to tune the resonant system. This spring would have to exert almost two tons of offset force for an 18" cone and have very low loss and high life. Of course your cone would have to be not much heavier than a usual cone in order to be as efficient, yet be able to withstand the developed force of the 15 pound constant pressure differential.
In other words, plan for a very large air filled box if you want infrasonic bass.
Yeah who knows if that's the truth, and for how long anyway. The thing is at some point you will be trading off between suspension nonlinearity and cone nonlinearity. TC sounds says the suspension is linear, but any roll profile with long straight sides is going to flex under drive. The total flexure over the whole surround surface might give a fairly linear response, but it's definitely all loss. Presumably some of these super sub manufacturers have thought about it longer and more closely than I have. The tape wire and stainless former seem like great ideas, because it's definitely going to take Power to drive that thing to xmax.
WiSounds wants 140dB's @ 20hz out of the the TC Sounds Pro 5100 18" Neo Subwoofer Driver.
Specifications: • Power handling: 1,000 watts RMS/4,000 watts peak • VCdia: 4" • Le: 2.8 mH • Impedance: 2 ohms per coil x 2 • Re: 3.02 ohms • Frequency range: 15 - 150 Hz • Fs: 26.5 Hz • SPL: 94.5 dB • Vas: 8.88 cu. ft. • Qms: 6.90 • Qes: 0.25 • Qts: 0.25 • Xmax: 31.0 • Dimensions: Overall diameter 18.52", Cutout diameter 16.83", Depth 11.27" • Weight: 53.4 lbs.
How about the Audiobahn 34-inch ?
looks interesting.How about the Audiobahn 34-inch ?
who can post some high resolution images about Diatone's D-160 (D160) ??
I can find only this pic -last pic about
here more interesting URLs arround large exotic transducers:
Audio Fidelity BG • ??? ?????? - ????????? ? ??????????????
Flickr: ????????'s Photostream
Forum des passionnés d'enceintes Cabasse, HIFI vintage et Home Cinéma. :: Bon anniv' !
Ideas needed, what would you do with a 24" woofer? - Page 4 - AudioKarma.org Home Audio Stereo Discussion Forums
In real life I hate such speakers and therefore I prefer speakers/transducers, that have perfect quality and that are produces in a great amount over a long time. The brand "Precision Devices" is my favorite brand.
about
http://www.diyaudio.com/forums/subw...ubwoofer-precision-devices-pd2150-inside.html
you will find some projects, that I have realized by various customer's
That model number is it and where I can download a datasheet?How about the Audiobahn 34-inch ?
video isn't remained
Adire Audio had the Parthenon at one time, not sure if it's still available through Dan Wiggins the creator.
Fs: 11 Hz
Qms: 19.4
Qes: 0.73
Qts: 0.70
Vas: 4560L
Sd: 3716 cm^2 (24" square)
Xmax: 72mm one way BL linear
Xmech: 140mm rearward one way
SPL: 91 dB @ 1W, 1m
Impedance: quad 4 Ohm voice coil
Cms: 0.24 mm/N
BL: 30.5 N/A
Re: 11.2 Ohms (all voice coils in series)
Mms: 880 grams
Vd: 53 liters
Pmax: 2000W total
When it was measured at CES 2004, it produced over 134 dB at 11 Hz.
Fs: 11 Hz
Qms: 19.4
Qes: 0.73
Qts: 0.70
Vas: 4560L
SPL: 91 dB @ 1W, 1m
Cms: 0.24 mm/N
BL: 30.5 N/A
Mms: 880 grams
Vd: 53 liters
Pmax: 2000W total
Fs: 11 Hz
Qms: 19.4
Qes: 0.73
Qts: 0.70
Vas: 4560L
SPL: 91 dB @ 1W, 1m
Cms: 0.24 mm/N
BL: 30.5 N/A
Mms: 880 grams
Vd: 53 liters
Pmax: 2000W total
Mean you the part from this URLs and the attached images?
Pics of Adire's new MEGASUBWOOFER (20 Hz, 121 db with no box) - Audio & Video Forums
http://web.archive.org/web/20040624124254/http://www.adireaudio.com/Files/Dan/Parthenon/
http://www.diyaudio.com/forums/multi-way/25050-adire-audios-new-motor-parthenon.html
Ultimate SPL subwoofer
By this transducer I don't understand, how it works.
unknown Transducer
Who knows the brand and model number of the transducer from the attached photos?
- Subwoofers
- Overview about words largest Subwoofer Drivers/Transducers (SUBWOOFER BEAST)
