I have been researching the Dean Markley t120R i own, since I inherited it and no little about it. Until recently when with the help of StephaninMelb I hadn't a clue! Hey I was a toddler in the 80's....
Still, I plan to 'restore' it, for want of a better word, and I will document as much as I can in pictures, and component values,(for those, like me cant read DMs schematic).
If this interests people then its a bonus, but I think this restoration may be slow
Here is some pic of my 120R, s/n t120r-047:
Front View:
Rear View:
The next photos show the output valves. All of the valves in general seem fairly old, though not really smokey.
The writing on all the output valves, as well as the pre amp ones is very hard to read. The pre's are all " GE 'Electronic *something* " 12AX7, The left pair of output tubes are " PM '6L6GC' ", and the right hand side pair read something like " PhillipsECG '6L6GC' ", and also the letters " ha AGX "
If you look closely they have radically different structures inside, and the Phillips ones look very interesting. I know little about valves but I look of them better.
Front View:
Rear View:
Cool,-- Do you have the schematics in digital form? If so, post them. This is the quickest way to get folks to chime in. Does the amp work now? Humm 4 6L6GC's humm. What power do the claim? I say that because they sould be good for 50W - 100W but the higher figure is one that I have always found optimistic.
Haha thanks for the interest. Yeah it works fine, probably due for new valve in the output side since the 2 pairs seem so very different considering they're both supposedly 6L6GC's...lol
Basically, as I shouldve said in the beginning, this thread was the spawn of an earlier thread:
http://www.diyaudio.com/forums/instruments-amps/152743-dean-markley-valve-head-120-watt.html
where I was seeking advice in general. using that advice, I'm hoping to renovate the amp a little. The pots are a little dodgy, it had some surgery to the internal wiring. The auxiliary mains output has been disconnected, which is probably no bad thing since I wont use it. Im planning on replacing the electrolytics too due to the age of the amp.
As for power, its a claimed 120watt, and from what ive read, or been told, it has quite a heavy bias. The stubby PM valves seem to show the dissipation, and the Phillips seem far more capable of tolerating the biasing. I now suspect these either to be the originals, or early replacements. either way older than the PM's. The pre tubes are almost certainly original GE's to the best of my knowledge.
Its a stunning guitar head, I think it deserves a fix up, so I can see what it can really do
RE: the DM strings....I dont buy them. I find they sound like no other string, in a good way, but the tone is gone SOOOO quick. I always end up going for my old 'safe' option, slinkys, whether the LP or strat just coz the tone seems to last 2 or 3 times as long.
From what ive been able to gather info wise the pots im planning to replace are:
VOL: 1Meg
BASS: 250k(A)
TREBLE: 250k(A?)
MID: 10k
REVERB:1Meg
This info all from the DM schematic, however 'VOL' could be 'PRE' or 'MASTER', its unclear which, and the 'PRESENCE' is also not shown (or not obviously) SO those values will have to wait until I begin dissecting the amp......
Also the PSU schematic is not available, and I hope to draw the schematic given time.
So far the PSU caps are:
1 of 22uF 500V
2 of 100uF 350V
2 of 33uF 350V
3 of 100uF 80V
2 of 470uF 25V
also on the Pre board:
1 of 1uF 50V
1 of 22uF 350V
VOL: 1Meg
BASS: 250k(A)
TREBLE: 250k(A?)
MID: 10k
REVERB:1Meg
1 of 22uF 500V
2 of 100uF 350V
2 of 33uF 350V
3 of 100uF 80V
2 of 470uF 25V
1 of 1uF 50V
1 of 22uF 350V
Next: components which CAN overheat
Reading some of the advice and literature, the latter of which there is little about, I checked for brown board, and found diode on the PSU board, and a couple of resistors overheating.
1N4746A (2 off)
1k 'RCD' type W/W resistor guessing 500V and 2-5W
1.6k 2-5W +/-5%
150 Ohm 1W +/-5%
All these components within a small area of PCB discolouration, the RCD resistor and diode being the main contributors, by appearance. I plan to replace these all just in case.
the underside of the board, another resistor_47k????(added by SOMEONE) connected to one leg of a 5k preset pot(bias?), and the original track scratched out. Unless this is bias related I plan to reinstate the track using 0 Ohm resistor. Not quite sure of the 'new' resistors' purpose....
Also small ceramic cap soldered directly on the leads of the 220k R near the 'Bass' pot, presumably the 220k on the wiper of the treble circuit.....another mod that im not sure is necessary and am a little mystified to its purpose.
1N4746A (2 off)
1.6k 2-5W +/-5%
150 Ohm 1W +/-5%
Schematic for those who requested it
Her is the 'official' Dean Markley schematic, from their site.
However, from a quick butchers' Im not entirely sure that it is correct in its entirety, since 2 pots are either missing, or are there but no values are attached so they arent obvious. The cap mod I mentioned above, I believe is on the 220K R in the top right hand part of the schematic.
At any rate this schematic is not nearly as complete as I would like! also It would appear to be ONLY the preamp section!
On my T-120R in the PSU section I replaced the electrolyic capacitors with RIFA brand. They are one of the few that are high voltage and appropriate quality. While I was upgrading the amp I had started to build a duplicate using a form of tag-boad construction. The idea was to end up with a Dean Markley clone. Ideally it would use turret board or eyelet construction. Also I would add any improvements the the clone amp. It is much easier to clone an amp when you have an original amp.
Your left hand pair of 6L6GC power valves look like a 1st generation Chinese type because of the coke bottle shape. Mine came with 4 Sylvania 6L6GC. Philips 6L6GC are also original quality type. When I retubbed after studing all the available new 6L6 types I ended up using Winged-C (SED). I wanted a tube that reproduced sound accurately and that was had good bass reproduction, since I occassionaly played bass through the amp. I found the Winged-C also handled the mids and upper frequencies well. I was especially impressed with the top-end frequency tone. It outlined the 2nd-order harmonics with a sweet sound but not cutting edge glassy. Almost a floating bubble 3-D effect. Mine also had GE 12AX7 in the reamp section, which would have been the original valves.
As far as the powr output it is rated at 120W with bias set at 100%, which no one would do on any amp. The T-120R has at least as much power output as a Fender Blackface Twin Reverb (which was rated at: 85W) and Fender Silverface Twin Reverb (rated at 100W to 120W). The T-120R can be set at very high B+ current, but the convention for setting all amps is 70% of tube maximum rating. Regardless of what level the T-120R is set at it is one of the loudest 4 x 6L6GC amps ever made. It will keep up with a Fender Twin Reverb, which are well know for being a loud pro gigging amp. With modern PA systems these types of amps aren't as critical as in the past, but still it is nice to know it has plenty of sonic volume reserves.
These Dean Markley amps were mainly sold to professional musicians for rack-mount in a large rig. The Eric Clapton and The Police rig were fairly typical configurations for this amp.
I had a pair of T-120s - a reverb model: T-120R and a non-reverb: T-120. These were loaded in a rack with Perfect Connection GP-1000 preamps made by Lee Jackson. I know of no better preamp and this model of preamp is now has a cult following because of rarity and sound quality. They rarely come up for sale and getting expensive. If you can find one - buy it!
I have tried over several years to locate the potentiometers used in the T-120 and never succeeded. The closest I could find were Peavey "spider" potentiometers. I believe there are correct matching values if you draw from the whole range. A small hole will need to be drilled in the T-120 preamp PCB to accept the lower middle leg. This is used to just stabilize the pot. These vertical PCB-mount pots are hard type to locate. Marshall, Fender and other mount their preamp PCB horizontal and this is the most common PCB mount pot type. It is the same issue for the vertical PCB mount input jack, but I did manage to locate the OEM source for that part. I've found that particular part is rugged and haven't had to replace them.
The transformers were made by Woodward Schumacher, who also for many years made all of Fenders transformers. Schumacher is still in business under a new name and can supply transformers if necessary. I've found them to be rugged and also parts I haven't had to replace. The only issue is on International transformer getting the values and in general the schematic lacks voltage readings for the transformer leads. It would be nice to get readings from that area and apply to a new schematic.
I too had brown board and the same 1N4746A 18V - 1W diodes overheating. With one of the two amps the board had been really heated up to where it damaged one trace. I had to solder in a patch lead to bypass the damaged trace. I understand the trick to replacing the parts is to raise to bead the diode leads into a L shape to raise the diode above the board and allow some air space. Use a spot of silcon to stablise the diode.
Those diodes need to be upgraded to 18V 2 watt in DO-41 axil package (2EZ18D5). Microsemi Commerical Components Group (VA) is one manufacturer. It should be common part to locate.
When replacing the resistors keep the same ohm value, but increase the watts rating to the next value up. Take a close picture of that whole problem area. The type doesn't matter as long as +/-
5% or better.
On the power lead going into the amp and before the power transformer connection check that there is no death capacitor bridging the leads. If you see one clip it out.
To replace electrolytics you can use Illinois Capacitor, which is original and still available or swap out where possible most of the values for a higher quality cap.
1 x 22uF 500V
.....Evox Rifa Peg124 is not available in this value
.....Illinois Capacitor 22uF 500V axil is same as original and still available - common in guitar amps
.....F&T Capacitor (Germany) 22uF 500V axil is a bit higher quality option
2 x 100uF 350V
.....Evox Rifa Peg124 Series is not available in this value
.....Sprague Atom 100uF 450V should work
2 x 33uF 350V
.....Evox Rifa Peg124 Series 33uF in 400V or 450V or equivalent
3 x 100uF 80V
.....Evox Rifa Peg124 Series 100uF 100V or equivalent
2 x 470uF 25V
.....Evox Rifa Peg124 Series 470uF 25V or equivalent <--- I've put an axil value here but was thinking this might be a vertical mount cap? I forget...
Take a pic of the PSU cap area.
5% or better.
1 x 22uF 500V
2 x 100uF 350V
2 x 33uF 350V
3 x 100uF 80V
2 x 470uF 25V
Note everyone. There has been a Dean Markley T-120R (Serial number: T1203-969) on eBay that was just passed in at USD$379 after not hitting reserve price. It was earlier offered at around $1000 Buy It Now Price. The problem with Dean Markley T-120 amps is that very little information is available on the Internet, so most people know little or nothing about these amps. Also until now through people like us very little technical information available. Because of the lack of historical and tech information people don't know how much bid on these amps. Also so few were produced that hardly anyone knows how they sound.
Only a few come up for sale each year Internationally. These amps at a minimum are worth $500 to $1000 (in that lower range because of the lack of brand awareness). In actuality these amps should be selling at the $1000 to $2000 level if they have been serviced to bring up-to-date. An equivalent new head built would cost over $2000.
I expect this Dean Markley T-120R will be relisted on eBay USA within the next few days. Good to be aware of it since these amps are rarely offered for sale. Most amps of this type would have had a pro player owner at beginning.
Here is the eBay listing:
http://www.ebay.com/itm/Dean-Markley-Signature-Series-120-Guitar-Amp-Head-W-4x12-Cab-T-120-Clapton-/190644279136?pt=LH_DefaultDomain_0&hash=item2c6348d760#ht_684wt_954
An interesting technical fact learned from this sale is that JJ 6L6GC are too tall for this amp. The current owner then describes how the protective grill that covers the top and back has to be left off. He then goes on to say that he read that many people leave the grill off and it is only needed in a rack-mount installation. I've never heard of this before and more than anyone I have trolled the Internet for info on this amp. Quite simply one shouldn't use JJ 6L6GC tubes if they are too tall to fit inside the DM T-120 enclosure. He should have returned the tubes to the supplier and purchased another brand of tube. Personally I wouldn't have selected JJ tubes even if they fit.
This sale also includes a DM 412 cab, which needs to be considered as it adds to the value of the amp.
This sale also includes the T-120 User Guide. It would be good to try and get a copy of this from the seller before this amp finally gets sold. This is likely to be only a simple 2-4 page document, but still be good to have. I have only once before seen a sale that included the T-120 user guide.
Even with the JJ tube issue this looks like a desireable amp as it has the 412 cab (with dean Markley Magnum Model 1280 8 ohm 80W speakers) and is the Reverb version of the T-120 = T-120R.
Ta Stephen, I had pretty much arrived at the same conclusions as yourself Vis-a-vis capacitors:
1 of 22uF 500V A right royal Pain to find!!!!
2 of 100uF 350V VISHAY SPRAGUE|53D101F400JL6|CAPACITOR, ELECTROLYTIC, 400V | Farnell United Kingdom
(bloody expensive! only other options involve paying £15 swhipping charge per order from US!!!)
2 of 33uF 350V Buy Aluminium PEG124 axial Al electro cap,33uF 450V Evox-Rifa PEG124YJ2330Q online from RS for next day delivery.
3 of 100uF 80V Buy Aluminium PEG124 axial Al electro cap,100uF 100V Evox-Rifa PEG124PF310VQ online from RS for next day delivery.
2 of 470uF 25V (radial) RUBYCON|25YXF470MEFC10X16|CAPACITOR, 470UF, 25V | Farnell United Kingdom
1 of 1uF 50V (radial) RUBYCON|50ML1MEFC4X5|CAPACITOR, 1UF, 50V | Farnell United Kingdom
1 of 22uF 350V Buy Aluminium PEG124 axial Al electro cap, 22uF 450V Evox-Rifa PEG124YH2220Q online from RS for next day delivery.
Since I work in power conversion, (commonly converters use 690VDC in DC link feed, and required Cap filtering) I may ask some of the purchasers, for a source for the 500VDC 22uF, and 350VDC 100uF, just to see if they know any other vendors that I am not aware of (RS,CPC,Farnell are about all) with any luck I may find something suitable. Pity they HAVE to be polarised, since I could get hold of PP caps for these values very very easily
Your selection of caps does closely match mine. I like the Peg124 better than Sprague but as we both saw they don't make that one value. I thought that 470uF 25V was a radial. I bought my Evox Rifa from RS Components in Australia. I think I also used the Rubicon radials in those values.
After I soldered the axil capacitors in place I then put a dab of clear silicon between the caps (at the top edge) to add stability.
yeah the originals are hotmelt glued together, and I have a glue gun so may well go with that.
On the Pot front, 1Meg vertical mounts are hard to find....
I have one possibilty though:
VISHAY SFERNICE|P10XXAI105KB30|POTENTIOMETER, 1M | Farnell United Kingdom (although log track)
also for 250k (although Lin NOT log )
BOURNS|91A1A-B28-B22L|POTENTIOMETER, 250K | Farnell United Kingdom
Have you checked for source of Peavey spider vertical mount pots in UK. The other vertical mount pots were not long enough to clear the enclosure. The Dean Markley pots are unique how they have that long casing around the shaft and then threaded on outer section. The Peavey spider pots reverse the vertical mount where the pot fits against the back of the enclosure and then uses the long legs to reach the board.
Haha thanks, Im going a bit crazy here
Although im considering just using panel mount pots, and extending the 'legs' with flash wire (just copper wire without the enamel coating)
I had a quick look at the Peaveys...i cant recall if they covered ALL the values necessary though....Also the 'master' and 'Presence' pot values arent shown on the DM schematic, and I cant recall if you listed them on your site (sorry), so they could be a problem too. One thing is that the single support leg of the Peaveys will foul a track, on at least one of the positions.
One the bright side, I have mailed DM support, and theyve directed me to an engineer they use, for a FULL schematic!
Some of the Bourns, and a few Vishays types have very long 'legs', and I reckon I could just bend them to orientate the pot vertically
22uF 500V electrolytic
100uF 350V electrolytic
F&T available in these values for 2.95 pounds / each from HotroxUK:
http://www.hotroxuk.com/amp-parts-service-equipment-294-0/capacitors-mallory-caps-sprague-orange-drops-6136-0/f-t-axial-lead-caps.html
Sources for Peavey spider pots:
http://www.stagebeat.co.uk/?page_id=500685
Brilliant!
Google must like you more than I lol
Here the pic showing PSU board and the pre board:
One option is still open to me WRT the pot issue.
I could use a piece of insulating GRP (plenty at work lol), on stand offs, and mount pre board horizontally.
Whatever I do, the pots present a further issue. BOTH the legs are used in the circuit continuity, to for the ground(?) path, so whether I use the Peavey pots or others, Ill have to sort that issue as well lol.
I would just cut off the legs of the current pots leaving the board side of each leg sticking out the PCB as solder points and go for panel mount pots. Then find a way like the L brackets and stand-offs to mount the whole board vertically. It looks like there is plenty of room and should be no issue drilling holes in the enclosure floor for screws.
- Live Sound
- Instruments and Amps
- Dean Markley T120-R fixer-upper project.
