Linx Nebula Schematic
Wharfedale
I got one some years ago from Wharfedale - for some reason they had taken on support of linx equipment. I suspect you won't have much success with this line of enquiry though so if you like I'll have a go at scanning it in and attaching it to a message on this forum. It's a little bit blurry so you might not be able to read all the part numbers, but it'll be better than nothing I should think.
Ooops - haven't been checking on this forum. If anyone still wants a (poor quality) image of the circuit diagram send me a private message with your email address. Also, let me know if your email server has a problem with large attachments and I'll split it into several emails.
In the attached PDF files my own created schematics from LINX model "Quasar" - perhaps helpful.
Who knows, who has overtaken this audio brand (resp. the currently brand name)?
  • C ...-A-Linx Quasar Logic.ckt.pdf
  • C ...-A-Linx Quasar Power Amp.ckt.pdf
  • C ...-A-Linx Quasar Pre I.ckt.pdf
  • C ...-A-Linx Quasar Pre II.ckt.pdf
  • C ...-A-Linx Quasar Pre.ckt.pdf
  • C ...-A-Linx Quasar PS Logic.ckt.pdf
  • LYNX 3 Schem www.audio-circuit.dk.pdf
Linx Nebula saved!
Many thanks to Paul (pfshepherd) for emailing the schematic. I tracked down a shorted :smash: 2sc2910 in the 12v logic supply which when replaced brought the amp to life. :D
The amp sounds pretty darn good - I bought it faulty so this is my first audition. I think it might be the best £15 I've ever spent! I think I even got a pair of bookshelf speakers with it iirc :cool:
regards
David
Linx Nebulla
need also a copy from the circuit diagramm ...thanks
joachim-schneider-web@web.de
regards
David
Hi pfshepherd if still available I would like a copy of the Linx Nebula schematic Please send to lindengraham225@gmail.com
Many thanks
Linden
Excellent! Thanks - how did you come to have these?
I have a photocopy of the Nebula circuit because I sent it for repair and asked for one. At that time Linx equipment was being serviced by Wharfedale. I am under the impression Linx has long since disappeared.
Hello, do you still have the Nebula circuit drawing? i would like to ask you (or anyone who has it) to send it to me , please.
Thank you!
