Some enclosures and chasises we made
RE2207
RE2207, looks so much like RE2205, except the height is 70mm
Outside Dimension:WxHxL = 215x70x228mm (8.46" x 2.76" x 8.94")
Inside Dimension: WxHxL=203.5x62x217mm (8.01" x 2.44" x 8.54")
Material: hard aluminum alloy
thickness: Front 8mm, back 3mm, side 3mm, bottom & top 2mm
finish: brush, hard anodized
net weight: 1.6kg
cutout available for 10pc+ order.
REF3208
This is a different type. frontpanels are made of aluminum, the body are sheet steel. body is powder coated, very nice. The benefit of steel is the cost is relatively lower than aluminum. It's can be used for DAC, Preamplifier, Power amplifier and tube gears.
REF3208:
Outside Dimension: WxHxL= 320mm x 80mm x 248mm
Inside Dimension:WxHxL = 315mm x 74mm x 236mm
Frontpanel thickness: 8mm
Back panel thickness: 3mm
body thickness: 1.2mm
material: aluminum (front and back) + Steel (body)
finish: powder coating (body), brush+hard anodized(front and back)
net weight: 3.5kg
RE4302
This is not designed for audio. It's for some sort of communication equipment. But I think no audio DIYer can effort not to being attracted by it, especially for those tube gear players. It's big enough, rigid, super good looking and effortable to everyone.
Outside Size: 430 X 70 X 308
Inside Size:415 X 59 X291
Finish: fine brush, hard anodized
Thickness: F, B, T, B: 8mm, 4mm, 3mm, 3mm
Material: Aluminum
Weight: 4kg
Hi Igor
Thanks for your suggestion. The problem is that I don't have the price when I post the images. The shop are handled by another dept, they are always slower than me. Oddly in the same country some said the website is fast, some said it's slow. I'll pass your concern to the info dept and see what they can do.
Hi Natawa
You can tell your friend to contact me by email or phone, We have no problem in sending him a few.
You said RE4105 in your post. I'm assuming it should be RE4015? It's a super good looking enclosure for power amplifiers. But are you sure your friend is willing to bring a 10kg enclosure back for you?
I have a suggestion for your website that could help prospective customers choose a case that include heatsinks.
It would be handy if a description of the heatsink was included in the product descriptions. Things such as C/W if available or the dimentions of the sink so the customer could calculate the C/W.
Mark :)
PS. Looking forward to recieving the cases and headphone amp component kit on Monday.
:eek::eek::eek:
Just courious how many DIY projects can you have at the same time? Most orders are 2 to 5 different enclosures since I post this topic a few days before.
These enclosures are all bought by an Australian.. Guess what will he build with them? :confused:
