300B failed again
Manta bought from a large Germany shop, surely a respected vendor and had this bad tubes!!
I start suspecting noone test any tube, by lack of time, test equip and qualified personal.
Too bad, so rest us to buy at VTS, UPSCALE and others top money tube brokers...:mad:
That's the bad thing about buyng on-line. If you can go to a shop you can ask for a test. That's the way I do usually for expensive stuff. If I cannot I just don't buy it. There are options as good as, or even better than, the expensive 300B. I think some people just cannot cope with this statement...:D...they must have a 300B, regardless of anything, otherwise it's not good enough!
Ok, thanks everybody.
I will go for the GuiGuang 300B. The Shuguang 300B-98 are nearly the same price but I give the GuiGuangs a try.
With JJ I had similar problems as with EH now. Their preamp tubes and rectifiers are very fine but not their power tubes. I've had it with their EL34...
The EH now goes in my display cabinet and my dog got the box it came in. He ripped it apart in seconds. Take that New Sensor corp ! :D
Any opinion on sound quality on these Guiguang 300B??
I also bought a pair for stock, they are metal plate and black base, no date code.
I have exactly the same problem as the_Manta experienced. I found one of my EH 300B gold grid tube with only half of the heater lit up. There is not a big difference in sound quality at low level but will distort when the volume is turned up. This pair was about 6 years old and cost US$139.95 a pair at the time. I have tried the Chinese Shuguang 300B before but didn't like it. So I have ordered a new matched pair of the same thing which now cost US$190.00 a pair plus shipping. I am not sure if this is a common problem with the EH 300B.
One time I pulled out my amp from underneath the rack to take a picture while it is hot and running, I wonder if this contributed to the breaking of one side of the filament.
I wonder is there anything I can do to get these tubes live longer, like putting a small resistor in series to reduced the voltage to, say, about 4.8 v. or something. Anybody tried the new Psvane 300B ? Apparently it is made in China by a joint venture of foreign investors and ex-Shuguang Engineers. The purpose is to clone the infamous WE 300B using the same technique and material.
Administrator
Joined 2004
<snip>
I wonder is there anything I can do to get these tubes live longer, like putting a small resistor in series to reduced the voltage to, say, about 4.8 v. or something.<snip>
It is quite possible that disturbing the amplifier with the tubes hot may have contributed to this problem.
I've had this problem (half filament dead) with a couple cheap Valve Arts 300B, and a number of SV300B - both more than a decade ago.
I've found CCS based heating of dhts to be generally a good idea, since inrush current is limited by the CCS to that required for normal operation you have neither the thermal nor magnetic stress encountered during uncontrolled inrush. I can recommend Rod Coleman's CCS having used them to heat GM70 for about 15 months now.
Thanks Kevin!
This failure does seem to have been a big problem with Svetlanas, Sovtek/EH and many other modern DHTs.
Using them with ac-heating, especially where the transformer is able to supply many amperes at start-up, is likely to be the biggest risk. When the filament winding is on the same transformer core as the HT(B+) supply, a high starting filament current is certain, because the HV secondary is effectively unloaded at switch-ON. The filament winding will give higher than normal voltage, and the cold-filament resistance of the 300B is less than 1 ohm (instead of 4 ohm hot). In this case, starting-current of over 5A is likely.
Wow this golden paper boxes are very beautiful.
They think the tube not need to perform good with this fancy package...:wave2s:
6 years its too much time, seems a fragile cathode or solder so far in this thread.
For one, those EH have really thin filaments compared to other 300B's.
Today I saw an old 1940s paper saying that 6SN7s in digital devices (computers) were more reliable when never turned off. Whenever one of the 20,000 6SN7's failed, the system would go down. The failures were almost always during turn-on or cool-down. The reliability of the 6SN7s improved hundred-fold when simply kept on. It took them years to realize this fact.
High current for filament at starting lasts very very fast. I think it is not major cause for filament's breakage. filament material is special for hot temperature.
WE 300B ampli have used also DC filament only with capacitors filter, but these tubes get very long life.
Almost indirectly heater tube use AC or DC (without CCS) for heater but I never see a case of broken heater for those one.
Administrator
Joined 2004
I've got to agree with Rod on this based on some experience with various brands of 300B and AC, DC and CCS based heating where I've experienced the best long term reliability with CCS heating of dhts.
The original WE amps all used AC heating, and probably filament windings with reasonably high dcr to limit cold filament inrush.. (They did not miss much)
Magnetic field strength during inrush and local hotspots both contribute to filament stress, a CCS substantially reduces both.
Comparing an idht filament with a dht filament is not valid due to many differences in construction, they generally run a bit cooler and are also more physically constrained than a dht filament is.
Material for heater of ID or DH tube is metal too, but somes are better or worse depend on the kind of material.
Almost ID tube's heater have DC resistance below 1 ohms, so they get big current in start of burning like DH tube. They is cooler than DH tube... I'm not sure about this :p
Some tube ID tube get flash at right time of turning on the power. You can see that phenomenon on many 9 pins tube of Mullards . Why ? I guess they maybe have very low DC resistance heater. But these tube is longevity.
Administrator
Joined 2004
I think filaments burning out is an even worse problem for IDHTs.
What makes you say that? :D I've built and sold dozens of amplifiers using all sorts of idhts and have yet to hear of a single filament failure, OTOH nearly every dht based amplifier has experienced one or more filament failures, none used ccs heating of dhts..
In 30yrs I've personally had exactly two idht fail due to filament burn out - both Mullard 12AX7A that fried due to inrush. (The bright flash, both of these tubes were NOS purchased in the 1970s and were barely used when they failed - both in the same amp.)
My current system has 18 idht and 4 dhts, previous iterations had as many 30 idhts and 4 dhts - none have ever lost a filament. My MR-71 tuner (not counted above) has all of its original tubes except in the multiplex and audio stages which I modified 3 decades ago..
