Was reading about this on a design pdf from here, Humble Homemade Hifi.
anyone tried this?
im tempted to try it with my B&W DM302's.
Any idea why it would make a difference or perhaps damage an amp?
anyone tried this?
Popularised by Tannoy and their 5th driver frame grounding terminal and
mentioned in : http://www.humblehomemadehifi.com/download/Humble Homemade Hifi_Solo-206_copy.pdf
Nothing to do with driver / speaker shorting as usually understood.
For Tannoy its just a marketing ploy, easily done inside the speaker,
and if going for an extra earthing terminal you need two, if bi-amping.
YMMV, rgds, sreten.
YMMV, rgds, sreten.
The idea predates the Tannoy 5 terminal thing, you find a lot of vintage drivers (Philips in particular) with a solder tage on the basket.
I have a feeling that it is related to groundside electron pools.
Unless you have a typical Class D amp or any other that is a bridged balanced design, the negative terminal on the amp is not grounded.
dave
dave
a) Is probably more do do with safety than anything else.
Probably a very good idea in old valve stuff to ground the
driver chassis, especially in lethal old valve televisions.
b) No comment. I'm not one for pseudotecnobabble.
c) I presume you connect the speakers extra ground
to the amplifiers casework if you are so inclined.
rgds, sreten.
Which requires a dedicated terminal on the speaker.
dave
The pic shows a 2" length of wire soldered from the - speaker terminal to the basket.
yes but how you thinks to fix the copper on Alu basket ?
I think some one stated something backwards.
Most amps have the negative speaker post connected to the chassis ground and the other channel's ground.
Bridged amps do not.
Class D, no clue what they do these days... tried to not look.
_-_-bear
PS. connect the basket to ground? Can it pick up a charge from the motion of the VC??
_-_-bear
- Full Range
- intentional speaker shorting?
