Quick and dirty, just snip lengths of 1/4" plastic water line sourced from your local hardware.
Haha, or just get some pens and cut them down, I used to do that for door speakers that wouldn't mount flush too the door panel.
Thanks for the link Perry.
Careful, because some of those holes have ground connection to the chassis. By placing a rubber or plastic grommet (ring) might break connection that may be needed.
I dont remember clips that hole the board or the screw, could you post a pic.
Wish I could, don't have a camera phone at the moment, I broke it. They snap in from underneath.
In either case none of them are grounding screws, I ran into that with a Lightning amp that had ground noise when I went to test it under load, didn't screw it down with every screw.
- General Interest
- Car Audio
- PCB Mounting Hardware
