Introducing the bit "Teleporter"
That and the LVDS signal level would be far too small.
Sorry, I do not quite understand all the technical details. For dummies:
If I just want to have galvanic isolation, I'd use IL715 chips as described here:
Which Digital Isolators for I2S? …or NOT H i F i D U I N O
If I want to have galvanic isolation plus the benefit of transmiitting the signal over longer wires, I'd use two of your Teleporter modules.
Question:
To have also galvanic isolation with two of your modules, would I need to cut/break the shielding (gnd) of the ethernet cable between the transmitting and receiving module ?
Cutout dimensions are 16.51 ± .25mm (.650 ± .010 in) across, and 13.95 ± 0.25mm (.535 ± .010in) vertically.
PDF for ethernet jack attached.
I will get a DXF file of the mounting pattern posted soon.
Here is a Front Panel Express file containing the Teleporter part. Right click and create a user macro in your library.
Also, a DXF of the part.
  • Teleporter.zip
Another use for the Teleporter will be to connect to a digital crossover or equaliser.
I use a couple of DEQX units connected to the XONAR card configured as quadrophonic and then feed their digital output into Buffalo DACs that, in turn, feed each individual speaker driver (the DEQX allows discrete calibration of each individual driver as well as being a crossover and room eq).
Tapping into the I2S made an astounding difference. The Buffalo DAC in concert with the digital processing capabilities of the DEQX is simply astounding. Unfortunately, running I2S any real distance is extremely problematic - particularly at higher bitrates. Hopefully, the Teleporter is the answer to my prayers :)
