Jfet BOZ
What is the voltage at the Drain of the JFET. It needs to be at about the middle of your supply or a little bit lower. Sounds like maybe the current is off a bit (Maybe high?). You can play with the Rs a little or the Rdrain or the supply and see if you can get some improvement. You want to get the JFET drain at about 8-9V.
Here's the problem...I put in 1 volt at 1kh and get out nearly 8 volts. But when I look at the output on an oscilloscope, the bottom going swing is clipping badly. In fact, the bottom going swing starts clipping when output is measured at 1.6v.
What to do???
Thanx
By the way, I used the jfet boz boards from Jim's Audio on Ebay. They are pretty neat, and include a power supply circuit.
The right supply voltage varies depending the jfet's idss (For get a low distortion)
IMMO for get more output voltage, you must choose the V jfets instead BL, and raise up the supply voltage to near of 25V to 30V.
Here you have a mod for get a voltage fine tuning for this board
I notice that when I put 30 volts on the rail...I can get 5.6 volts out of the pre amp without clipping...beyond 5.6v I get the onset of clipping...
I thought 18 volts was the sweet spot...should I operate this preamp at 30volts??? or stay at 18 volts and adjust the drain resistor...I haven't tried working with the drain resistor yet...
There is no reason to be focusing on the "sweet spot" until you understand why you have a non symetrical output waveform. I think the first place to look is the drain of JFET. The Idss value of the device you have is likely the most important variable in the problem. But, I suppose you have what you have? And, the suggestions to mess with it are not going to come with a new JFET, with those designers personal favorite Idss values. Generally those comments are correct. A higher Idss value device ussually gives the best results when set up correctly. But, is that what N.P. uses in the production units?
As I said, knowing the drain voltage you have now, will give you insight into what to change and how much to change it, to get close to a "sweet spot" without a new JFET.
Just my 2cents. And just trying to help.
Sounds to me like your current is high. This means your JFET Drain is to low of a voltage. You could lower your Drain R or increase your Rs. I would play with the Drain R.
Increasing the supply is also an option. But, with that comes power dissapation? Is the current to high??? You could measure the actual R of the Drain R, and measure the in circuit voltage and you will know the current in the circuit.
thanks for the advice...
with power supply at 18.5 volts and drain resistor set to 1000 ohms, the voltage on the drain of the jfet is 9.4 volts (measured between drain and ground). Onset of clipping is now 3.6volts and is symmetrical. The input signal to the pre amp is .3 volts. These voltages are measured by a meter so they are rms. The current through the drain is 8.6ma.
Does this sound right???
QUOTE
yes.....symmetrical clipping, drain res around 1k.........should work.
with a drain res = 2,2k psu at 18v is too low.........34v as shown in the pass schematic will fit.
here is an example - sim:
input sinus 200mv red, output = green
with 18v ........and with 34v
I presume your JFET has the Idss of 9.7 mA. With 10 Ohms source degeneration the Id will be about 7-8mA.
2k2 x 7mA = 15.4V - This means that your JFET works with very low Vds and that's where the early clipping comes from.
Reduce the Drain resistor to get about 8 Volts at the Drain, but don't expect to get more than a few Volts of clean swing from that design.
My BoZ and BoZSE produce 17V p2p of swing before any degeneration of sine wave. I run mine on 27V. I'm using the BL series of jFets.
I have an orginal BOZ driving a SE MosFet Power Follower amp (which has effectively no gain). The combination provides more than enough volume on my ancient Whatmough 202 speakers of 86dB sensitivity.
My question is: Will the JFet BOZ be able to provide similar dive capability as the older BOZ? The power follower amp needs about !0V RMS to drive it.
Joe
