photoshoot OB MK1, at least they sound good
It is a open-baffle with Kugelwellenhorn. Ad old and new year I had time to finish the Open-baffle loudspeaker and it took a lot of time to think about the best solution and build it.
KUGELWELLE
Hi Janicol,
Here a simulation of the alpha 15A. With corner placement even 96dB 1wmtr 26Hz -3dB is possible. Simulation shows 1Phi placement .
  • alpha15a.txt
This efficiency and sub-low in this compact design and low group delay, low phaseshift is unique. Only stupid people build a onken.:D
This design doesn't use the eminence alpha 15a
