hi apex sir,
can u check for any errors,
how much power i can get from this h900 tef 8 pair, into 2ohms?
what is max transformer va need for stereo?
and the voltage,
is it need two psu to stereo?
for the protection ?
For 1500W into 2 ohms U need 2000W transformer, use two PSU for stereo.
thanks sir,
is it 2000w transformer is one channel or two channel?
Why are you insisting on 2 ohms? Could you tell us what kind of speakers do you have? Do you wanna parallel four 8 ohms speakers per channel?
yes hightec,
300w /4, imf speaker.
300/8ohm,4 speakers per channel,
Well, like AndrewT already suggested all you need is 2 stereo amps, 2 x 600W/4 ohms on each side and parallel their inputs. Each channel would drive 2 paralleled 8 ohms speaker. Well, at least it's more simple to build and a cheaper solution as well. Would you guys agree with me?
so need two chasis and two transformer.
and lot of work to do.
I suggest use 2ohms capable amplifier to drive 4ohms speakers for PA setups.
i am selling for djs, and their using in outdoors.
so this h900 tef is not capable for 2ohm loads for pa?
Is this commercialisation of designs taken from DIYaudio?i am selling for djs,
Is this allowed by DIYaudio?
Is Nazirdigi sticking to DIYaudio rules?
- 900W H-class PA Amp with Limiter
