LJM Audio
What is the advantage of a regulated SMPS over non regulated? I'm afraid I don't know much about the technologies in each.
Regulated power supply provide constant voltage, regardless of the load.
Un-regulated power supply output voltage may vary, according to the current required by the load.
ClassD amplifiers have a relative lower PSRR (power supply rejection ratio) than traditional classA or AB amplifiers. They behave better with a regulated power supply.
L15D problem.
I bought a pair of L15D on ebay.
I tried to power the boards as per the daigram on the sellers site.
I used a meanwell SMPS at 55 vdc and the amps did not power up.
I tied to PM ljm but his in box is full.
Can anyone help.
Best Regards,
elb
Can anyone help.
Best Regards,
elb
Hi Elb
I have L15D - it needs a slit rail supply with +/- rail and ground. Meanwell SMPS supplies only single rail only - are you using two Menawell supplies for +/- 55V DC?
Can anyone help.
Best Regards,
elb
Yes, you need dual voltage. + - 55V. You can see the power of your instructions.
If you have two identical single-voltage, and their ground and did not turn, you can get dual-voltage series.
Be careful on the power supply. :D
No Documentation
Took almost two months but I finally received the L7.
Only problem is that no documentation or schematic came with it. Tried to get a schematic but the only thing they sent was one that looked like post #5 in this thread. That's a joke for a schematic,especially if you have a problem and need to repair it.
This is the first kit I ever ordered that didn't come with any documentation,just
a bag of parts. The pc board looked proffesional.not bad at all.
I purchased the L7 kit from a guy named zoe_tsang on Ebay.
Looks like ljm_ljm of this thread is the designer of the amp.
I'm not trying to rip off his design,which looks like a good design but nothing special. I just want the schematic for future reference or if I have a problem.
Maybe the Moderators should have put this thread in the Commercial section.
The main point of this missive is to include documentation in your kits.
sam
sam
It is a very simple AMP.PCB above the logo like this figure,
One look will understand.
It has many of the parts are dedicated, if the damage that is irreparable.
