Simplistic MosFET HV Shunt Regs
iko
Ex-Moderator
Joined 2008
voltage across R4 284V
Puresound MM if you want I can remove & connect a dummy load of 15K
voltage across R9 0V
voltage across R5 0V
Yes, you should fix it first with dummy resistor load.
0V across R5 is completely wrong. The shunt mosfet, Q3 isn't working at all. It needs something like 2V-4V across R5 (Vgs) to start working. Take Q2 out and measure with the diode tester between B-C and B-E. One way there should be no reading. The other way you should get a value that is close to each other (B-C and B-E).
iko
Ex-Moderator
Joined 2008
Roughly, this is how the circuit should measure if it worked correctly.
Joined 2009
MJE350 B-C & B-E close reading.
