100W Ultimate Fidelity Amplifier
This pcb is OK,
Ok, then continue...
some pictures
this is how I made my "hand made PCB" :scratch2::scratch2:
maybe useful to someone else
made it with steel needle, permanent marker & scratch :scratch2::scratch2::scratch2:
scratch with a piece of cutter blade that I tied in a pencil to correct the drawing
I hope that picture enough to explain what I'm doing
@dodoet
if we add another 2 pair it is not AX14 anymore, maybe you can make AX20 instead, don't forget to share
see page 92...
I'm also have a plan to add 1 pair more to AX17 but maybe it not necessary
made same or close to the schematic first then we can modifies later
My AX17s duel
Use 47uF and 47pF,
ok, almost done...
for testing I will use "bulb tester"
It is same as testing AX14?
And for bias
2 volt on 100nF or 15 mV on 0R33? What is the ideal voltage there?
I will supply 32v from transformer or better with lower voltage first?
I make 2 AX17 with different transistor, hope that not any problem happen :)
ok, almost done...
And for bias
Nice work, yes testing is same as AX14 and set 15mV on 0R33 for bias (50mA)
passed 1st test
Voltage 2x32vac on transformer will be OK, but you must disconnect transistors from heatsink, use liskun isolator.
Like this picture?
I'm happy now, thanks to Apex
These AX17s just passed the test easily
the sound is very clear even I use ugly speaker without enclosure
just for first test...
both of AX17's offset are very low, I try to hear any hum but nothing on that speaker just like it was disconnected from the amp
maybe my cheap digital tester was broken, I also can't measure voltage on 0R33.
my AX17s not use trimpots, because i don't trust trimpot that I bought.
I replace 220 + 1k trimpot with single 330ohm resistor & I got about 2.30volt on C7(100nF)
Is this voltage need to be increase or decrease?
AX17 using TEF right, or just similar look?
so if I increase to 3,2volt(with big heatsink & enought supply) it is possible?
because there was someone told me that he run the TEF amp with 3,2volt bias voltage, even more..
For other DIYer you also need to try this AX-series
I also want to make the AX14 like what Apex recommended :) to compare with this AX17.
As usual with new way hand made PCB(my version)
Thanks again
Like this picture?
EAX17 using TEF right, or just similar look?
Thanks again
Any sound difference SanKen vs Toshiba
Okay, so I need to increase it to 3,2volt & also measure voltage on both 0R33
the more important is the voltage on those resistor. Ok, I get it
TEF for 4 ohm load.
I just go back on this page, TEF for 4 ohm load
If there any possibility to try this amp on 2 ohm load?
Maybe on 2 x 25 vac
I just want to know :)
my plan is used this amp on 8ohm speaker
When I test it at first time I don't use good speaker
but I hear a little sound difference SanKen vs Toshiba
Toshiba seems clearer (mid high) than SanKen, but the bias not really fair I guess
since Sanken maybe need a more bias (my guess)
I will set proper bias then
I will make it sure when I finish this project
Perhaps I also can make visual measurement with any PCscope
Maybe on 2 x 25 vac
For 2 ohm add another pair of outputs, and VI limiter is recomanded, but for home audio it's work without changes.
AX14
I have made PDF file, if someone want print more PCB in one page A4, everything is a mirror reflection for thermo-transfer.
  • APEX AX-14 (2x PCB 2x Top Viev) [thermo-transfer] MIRROR.zip
  • APEX AX-14 (9 x Mirror PCB) [thermo-transfer].zip
  • APEX AX-14 (9 x Mirror Top Viev) [thermo-transfer].zip
