3" driver audition Fostex/Mark Audio
When a wave from the driver goes across the baffle, the edges diffract the sound, acting as a secondary sound source, with a small delay between the output from the edge and the driver itself.
If your system has a balance control, sit much closer to one speaker than the other, then adjust the balance so you can hear both speakers. Note there's still not much of a stereo image.
The reason for this, so far as I can tell, is that stereo imaging also needs low-level delayed signals, such as room ambiance.
When you have these wide baffles, you get a delay that's constant for each instrument (assuming a single driver, centred on a baffle), as well as the varying delays in the recording to indicate room position. This has to screw up the imaging at least a little.
Angling the edges reduces the actual output from the baffle edge, as well as making the baffle narrower, so these delays won't have so much effect. The narrow baffle has a delay so small that you'd simply think it was from the driver.
Chris
Kudos for pointing this out. I didn't realize big cabinets could image until I learned this a few years ago.
These small drivers are so close (with different strengths) a lot comes down to subjective preferences and which strengths carry more weight.
I fortunately am in a position to change them out as often as i like. If i was only allowed 1 set, of the ones i have on hand i'd choose in this order (with comments). Note that all drivers are treated, i do appreciate the differences (a different ranking might well ensue with stock drivers):
1/ FF85wKeN in uFonkenSET (if space constarined the regular uFonken v2)
2/ A6PeN in milliSize (and it would jump over the above if lower bass a requirement) Haven't tried them in anything else, the small box is under construction and i've yet to design the bigger box.
3/ mFonken (looking forward to tasting mFonken v2 with FF125wKeN, stock vrs stock the new driver has an advantage)
4/ mMar-Kel70 (neck & neck w above, more bass required would give these an edge, the mFonken i have are visually stunning so that doesn't hurt their ranking)
Founteks were given a ride, they will fit a small box like FF85wk, but since they have gone from $30 to $50 with the price of Neo, a set of 1 or 2 at a similar price are a level higher.
This driver is $38 and has an efficiency of 87dB. It's very very very limited in xmax - just 0.35mm. It has a conventional motor and no shorting rings.
This driver is nine dollars more. It has 3dB more efficiency. Even better, it's a prosound unit conservatively rated to take more than twice the power of the Fostex, and nearly ten times as much excursion It has an underhung neodymium motor. Distortion is likely lower than the Fostex.
It's a heck of a driver - one of my favorites.
I was once very interested in this driver, until I came to the conclusion that there was simply no way that it really had a sensitivity of 91 dB. In fact, take a quick look at the parameters, and it's easy to see that the Fostex is likely to be slightly more efficient. So, in regards to the 3FE20, either they've defied physics and the numbers are way off because they want to keep it a secret, or they're lying -highly likely since they're marketing it as a "professional" driver, and sensitivity ranks very high in that market.
On the other hand, have you measured this driver's 1w/1m response on a flat baffle? I'd love to see it, seriously. I'm still curious about this driver. I started a thread on it some time ago asking about sensitivity, and no one posted. So far, I still only see one possibility here.. which is that sensitivity is more like 86 dB 1w/1m, if that.
frugal-phile™
Joined 2001
Unfortunately it doesn't sound as good...
dave
We can calculate efficiency using the published specs, so it should be pretty easy to see how the two compare. The Faital's re is 6.2 versus 7.2 for the Fostex.
I'm a big fan of small drivers - I have a pile of them that I've tried - but xmax is a very very important parameter IMHO
For instance, Madisound and Parts Express have been selling some inexpensive Aurasound woofers, and the cheap ones sound 'congested' due to the limited xmax. The more expensive ones, with more xmax, are noticeably easier on the ears, because it's easy to run out of displacement when your cone area is so tiny.
I was talking along the lines of sensitivity, rather than efficiency.
I was also looking at the discontinued FF85K that I'm dealing with here, rather than the current FF85WK. In that case, Fs is lower and Mms is higher with the 3FE20. FF85K has extended HF, and a cool surround that doesn't protrude out from the cone. And if Dave's measurements are reliable, it has the flattest impedance curve of any conventional 3" driver I've ever seen. Regardless, it seems as though the 3FE20 is no more, replaced by other drivers (3FE22 and 3FE25). Looks like US Speaker might still have some though, but for $46 each, I'll pass. I wouldn't expect any more from it than your average TB 3 incher. IRT the xmax thing.. when you're using it as a large bandwidth tweeter with a series 1st order, excursion isn't of much concern. Even then, while certainly limited, the FF85K doesn't seem to have any problem moving a couple of mm.
Okay, I plugged the specs into hornresp. At 1khz, the Faital appears to have about 2.5db more output. Obviously at low frequency this gap narrows, because the Thiele Small parameters of the two drivers are so similar. So at low frequency, they're practically the same. (The hornresp plot is a vented horn with 1.2 liter of back volume and a 1" x 3" port.)
The real advantage of the Faital is it's xmax, which gives it more headroom at low frequency, and it's underhung motor, which should reduce it's distortion when compared to a ferrite motor.
As far as comparisons to TangBand, I think it's a moot point. TB drivers are oriented for hifi, and tend to have more low frequency output at the expense of efficiency. The Faital's efficiency is more in-line with the Fostex drivers, but higher.
Oval drivers are a bit of a fetish with me. Are there no good current production drivers outside of automotive applications?
Would the "oval" TBs have any advantages due to the shape?
When using oval drivers in an array are they mounted long-ways or short-ways so the centers are as close as possable.
BTW. Thanks for your time here answering posts with your business to run and being a caregiver. Very appreciated.
elliptical drivers interest me alot (rather than the TB type ovals). Mostly the ellipticals Ive encountered have been pretty awful, (though I stopped looking for good ones over a decade ago), and im no expert in that particular field.
Ellipticals interest me since reading V. Capel's book when I was 13 or 14. It would seem to me that they have the advantage of (generally) a broadened/lessened in Magnitude lateral cone resonance. I forget the correct term...(im studying an electrical/control systems degree, and knowledge seems to escape my brain as quickly as I fill it....)
Should the likes of Mark Audio persue an elliptical 4" by 6" or 6" by 9", then I should most certainly be interested in seeing a little more, since I havent seen any ICE ellipticals that had a particularly good response(FR/co-axial or midwoofer type-perhaps I havent looked hard enough. Any that seem to be generally available in the UK, are either in TVs or turntable/amp combos from the 70s. These are in general pretty awful, though surely some good ones must exist, even if theyre as rare as rocking horse $***.
Saying all this may sound like im damning all ellipticals, but im not. Id love to find some to make a good 2 way or coax, or FAST if i could find a small enough one to compliment.
Anyone tried Elac 301.2? They call it an off-axis co-axial. Unbelievable that they can mount a 3" x 4" driver into a case that small... I guess they have integrated high pass to lower the bump caused by mounting a high displacement driver into such a small case.
Many years ago some-one in UK designed what he called a differental wave driver. From memory it was a modified Fane round unit, with an aluminium oval glued to the inside of the paper cone. Written up in HiFi News when it still published good stuff. Claimed it gave a much smoother frequency response with fewer resonances. I have the article somewhere. Anybody else remember that?
