Power Amp with Hawksford VAS and EF triple here Audio Amplifier Design and Circuits | hifisonix.com.
I know. Have you fixed it's tendency to self destruct yet?
BTW, re Cdom I was referring to local feedback around the VAS stage, not global feedback.
I am well aware of that too. However as this only happens in the context of a circuit that also has an outer feedback loop this is not a case of feedback increasing with frequency. Of course Cdom compensation also has other problems.
What really happens is that for the whole system feedback decreases with frequency while at the same time distortion increases with frequency, so less feedback is available precisely where it is needed to linearise the amplifier, making a strong case for broadbanding and linearising an amplifier maximally prior to closing any feedback loop and to keeping the feedback constant over the operating range of the feedback amplifier, as defined by it's input filter.
Of course, if we have done this to a sufficient degree we may conclude that the global feedback loop has become optional and possibly even counter productive...
Ciao T
www.hifisonix.com
Joined 2003
It is fixed and running again. As to the root cause, I do not know, but extensive testing during design and more recently during the repair and then a bit later to TMC comp it tells me it was not instability. Getting carted from EU to Japan and then to Taiwan is probably not the best way to treat something like this.
I think linearizing before closing the loop is a given. As to wide OLBW vs high loop gain and LOLBW, I doubt there will ever be agreement on that. For that reason my new amp is jumper selectable for std MC, TMC and VAS loading although not MIC. This will allow for some experimentation. Of course, it's EF triple again and >100V/us, so no TIM issues.
Let me put it this way, if the LOLBW Designs where pure, absolute theoretically ideal integrators there would be no debate. And of course, in theory there is no difference between theory and practice.
You may, in your amp, when it blows up the next time (trust me, it will) reduce the VAS loading and increase VAS degeneration significantly and swap your triple for a Lateral Fet Driver and standard output... The 2SK214/2SJ77 remain available for the job...
Somehow triples seem more likely to blow than EF2... N-Joy. Better sort out reliable speaker protection... :)
My next Amp will be open loop, except the output stage, which will use all lateral fet Sziklai circuits... Not sure about the rest, maybe I'll just stick an open loop tube there, maybe I'll do open loop Fets...
Ciao T
The main selling items are <snip> Bedroom DJ Gear.
All I can ask anyone to do is to use IC's, beat me at my own game of audio design, and get rich and famous for it. Then, I will know that IC's have 'come of age' and I can concentrate on systems design in future. No excuses however, will impress me, if you fail.
Well, yesterday I purchased AMR CD-777, a CD player designed by Thorsten Loesch, having a tube analogue stage. The most analogue sounding CDP I ever heard. (I didn't hear the better model, AMR CD-77, since I can't afford it).
Each is welcomed to ones' own conclusions.
As for myself, it reminds me the English saying: "The proof of the pudding is by eating".
Tube analogue stage, Joshua? That sounds OK to me. I don't know why, but tubes do help quell digital problems. I find most IC based, CD analogue stages very weak, including the Sony SACD player that I use. Garbage, actually.
Now let me be clear. I am NOT against IC's. I have played with IC's since 1966, when they cost $100 each. I have measured them, hooked them up in simple circuits, and even designed them into instrumentation, 4 years before 1970. They are great for many applications, but I have always had some trouble with them for audio. Not necessarily unacceptable, sonically, but compromised compared to the best tube and discrete solid state circuits. That is where I stand, today. Now, if someone makes something that meets or beats Charles Hansen's or my best with IC's, well my hat is off to them.
However, the world must acclaim your design, before I will believe you.
Hi Joshua,
Merci beucoup.
Do try in DAC Mode with a Computer Transport as well, it is quite good...
Bon appetit. I would suggest a topping of nice NOS Tubes. The Soviet 6N1 sounds pretty good for something readily available, but better sounding tubes exist.
Incidentally, this CDP not only uses tubes but also omits looped feedback, though I have not gone to any extraordinary length to avoid local degeneration (I just did not design a lot of it in). It also allows the bypassing of any analogue and digital filters.
Ciao T
Scott,
Why don't we instead compare apples with apples, shall we?
Let us say we have a discrete OPA with 120dB DC Gain and 20Hz bandwidth with an SE class A output.
Due to the vagaries of epectronic design the 20Hz bandwidth corner is modulated by around +/-2Hz over the whole swing of the OPA VAS. What is the effect in band for a 20Hz-20KHz bandwidth? Non-Linearity (whatever you want to call it) from bandwidth modulation.
Now let us take the OPA and degenerate input by 20dB and VAS by 40dB (Yes, this will loose us output swing and increase noise, we may need more supply current, all no-no's in IC design, but "fair game" for audio). We will find we need to change our compensation to a much smaller one as well.
We now have appx. 70dB DC gain (because the VAS operates in current input mode, and degenerating raises it's input impedance and thus the gain if the IPS) 70dB gain at 1KHz and even close to 70dB at 20KHz. There is no or very little bandwidth modulation, as the parameters that cause it are all stabilised much better due to degenerating the devices Gm.
Ciao T
I would say you made an orange out of the apple. :) IIRC "The Love of Three Oranges" was one of the old RCA "super disks".
Hi Thorsten,
Merci beucoup.
Thank you for my enhanced joy in listening to music.
My music computer is kaput right now… however I will definitely try it.
BTW, the previous upgrade to my sound setup was a power amp by Nelson Pass, which made marvels to the sound of me setup.
Yes, I plan to roll the Soviet 6N1 with some NOS E88CC tubes I have.
I tried all the options and I prefer the default one, NOS (no oversampling) with analogue filter.
I have a feeling that part of analogue sound of that CDP is due to the DAC chip used, which AFAIK isn't being used in any other commercial product. Also, I noted very big output caps. So, it seems that everything matters.
Anyhow, after eating the pudding I've found that your design principles are working.
Joined 2002
In thinking of product ratings and design one category that has done well with IC's is DACs and CD players. My favorites have been discrete along the lines John has pointed out, but many over the years have had IC opamps not revealed in reviews. Of course the D1 was discrete as a matter of principle.
Wayne,
I would suggest that the reason is that few people know how really design digital audio systems from scratch and how to implement circuitry that is radically different from the Datasheets.
I remember seeing several DAC's and or CDP's using Burr Brown DAC Chips and Op-Amp IV and even the GIC filters EXACTLY as per datasheet followed by extensive and expensive discrete buffer circuitry.
This is surprising when a simple common base/source I/V and LC filter instead of GIC would been by far more to the style of the company making them and would have allowed comparable specifications as well as (from where I stand) trivial implementation... Would it have sounded better? IMNSHO, abso-funking-lutly...
I've even seen Op-Amp's in Naim's top of the line CDP's and DAC's when Naim has (in theory) their own discrete stuff that would be easily usable if they only would apply themselves...
Ciao T
PS, in the 90's I wrote a little article on how to use "pure" tubes with DAC's...
http://www.fortunecity.com/rivendell/xentar/1179/theory/vasfda/vasfda.html
I updated this nearly two years ago and submitted it for publication in Enjoy The Music's DIY Magazine, but Steve has so far not included this updated version for publication and I no longer operate any website suitable for publication myself.
I was playing with similar tube line stage:
The 12AU7 is one of the worst possible choices for line stages.
Try replacing it with a 5687 (or a russian 6N6 if you don't want to use western tubes) with around 500 Ohm cathode resistors...
Even better, make the upper triode's cathode resistor a J-Fet selected for the right current.
Ciao T
1970's Op-Amp
Guys,
As we have been spending time bashing how bad 1970's Integrated Circuits where, here is the schematic of one of these that originated in 1973.
I find it rather good...
Noise will be a bit high by modern standards (around 7nV|/Hz at 1KHz and 14nV|/Hz at 100Hz) but slew rate and bandwidth of this circuit where quite good and many modern "Audio Grade" Op-Amp's are dramatically worse...
Ciao T
Folks,
Guys,
Ciao T
Seems at least on my browser the schematic does not display, here as attachment instead...
Ciao T
AX tech editor
Joined 2002
I would rather say that they (tubes) overlap the source material by their inherent distortion pattern, which is pleasing for many listeners, but not for everyone.
That is something that has intrigued me for some time.
Just to make sure that I understand it:
Assume we have source material with a nice spray of harmonics, like from a violin or whatever. We send this through a tube stage with also a nice spray of harmonics, like a monotonous decreasing 2nd, 3rd, 4th etc.
The result, from the speaker, would have, say, 3rd harmonic from 2nd harmonic = 6th, or 3rd from 3rd = 9th, etc. In general, you generate higher order harmonics, including odds, from what's in the source.
Would this then be pleasing for some listeners?
jan
