Compactron Regulated Power Supply
Has anyone tried this particular power supply for any projects?
The possible probelm with this circuit comes from the low amplification factor of the triode of 6JZ8.
The PSRR of the whole regulator is only some 33 dB at best.
If the triode were hi-mu type like 12AX7, the PSRR would be more than 10 dB better.
The regulation of the output voltage is also better with hi-mu triode.
The PSRR can be improved some 10 dB by connecting a 220 nF capacitor between the output of the regulator and the grid of the triode of 6Jz8.
For most applications 6JZ8 works surely well enough.
I have used similar circuit, but built with 6L6GC and 6AU6.
Thanks for the suggestion, would it help to use a VR tube instead of the neon bulb?
Hi reg's
it is correct that you can improve by using a hi mu triode, however a pentode ca give you mu of 1000-1500, EF184
you can improve just by connecting the pass tube as a pentode, with well regulated g2.
I use EF184 and EL34 im mu reg psu, both connected a pentodes.
best regards
karsten
Yep.
My design uses the same basic topology, however, I'd bet mine performs better. A single triode for the error amp isn't going to give very much open loop gain, and will compromise the closed loop error correction, and therefore, the voltage regulation. That's probably OK, if you don't need tight regulation, but that's OK for a basic, adjustable bench supply.
For good performance, you need better in an active screen regulator, both in regards to voltage regulation and Zo -- both of which improve with increasing open loop gain.
For a 40V variation in DC rail voltage, this regulator showed an output voltage variation of 0.8Vdc for the required 270Vdc for the screens of Class AB1 807s.
Not too sure about using a neon panel lamp for the reference, as these aren't rated for a lot of current. A voltage regulator VT or a voltage reference VT would be a better choice.
Yep.
Really nice!!!
Hi reg's
best regards
karsten
would you mind sharing a schematic . im building all these regulators at the moment . and i want to see if a pentode really gives better characteristics as a 6080
have a good one
I've stumbled on to one problem that I hope someone can help me with. I had mentioned in a previous post that the supply worked great,well that was with only +140VDC,which is all that my preamp curcuit requires,but I decided to use the recommended input voltage,which is roughly 300-350V,and I was only able to adjust to +150VDC,and I was wondering what could be causing this,it says it will regulate to 250V? Thanks
Hi folks,
in all schematics shown here in this thread the pass through tubes work as triodes! So regulation behavior should be comparable to real triodes, such as e.g. 6080.
To get the advantages of a pentode pass trough, such as much lower voltage loss across anode and cathode, you will have to add a auxilliary source to feed the screen grid, which is connected between cathode an screen of the regulation tube.
Best regards!
I've been using the regulator on post #1, and is able to regulated to 250v. I have been using the regulator on a phono preamp (RCA Circuit) and recently with an Aikido line stage. Works without any issues.
What is the voltage you getting across the Neon lamp ? If I remember correctly (Big chance that I may not) ... I was reading a little bit above 90v
