hi apex sir,
i think the in4148 wrong direction. am i correct sir.
Yes, 1N4148 wrong direction.
hi apex sir.
i think this image is hv25 and working pcb, am i right sir.
only change is 10k instead 6.8k/1w resistor.
This amp is similar as HV25, but work in class H, there is step driver with IRF3205 and IRF4905 add in rail like in H200 http://www.diyaudio.com/forums/solid-state/162081-dc-servo-mosfet-amplifier-8.html
Hi Apexaudio,
Is HV25 the final design of this MOSFET Amplifier IRFP240/IRFP9240? If so, in which post can I find the PCB layout & schematics. Going through all these pages makes me go insane. I need to build this amp. Need your help. Thanks.
I share HV23 and that is final design, there is no HV25.
HV23
If the hv23 is the final, in which post can i find the accurate pcb schematics?
dear alex mm,
can send you send me the pcb ,and parts list of this hv25 amplifierat my e-mail khan.shahid251@gmail.com
thanking you masood
thanking you masood
hi apex sir,
hv23 5 pair output in progress.
hi apex sir,
Nice work, you need PSU and protect also.
thank u sir.
hi apex sir,
i supply power to hv23 5 pair.
supply voltage 46v,0,46 dc.
dc offsett showing 30v dc, what will be the problem?
i measured the 15v zd, showing 6.5dcv.
i adjust the preset to 2v from 10ohm 10watt from the power rails.
Connect input gnd to psu gnd, I must use this for my signature
- MOSFET Amplifier IRFP240/IRFP9240
