F5 power amplifier
Thanks for the comments guys :)
NS: Tried swapping inputs already and that makes no difference, the hum stays in the same channel. I have a (dual-channel) scope, so I will do some poking around with that :D
Andrew: Curious as to why you recommend this, is it because of the load on the PSU (the amp is dual-mono, so presumably no difference) or because of grounding?
/U.
They will share some wiring. They are no longer monoblocks.
If we were sufficiently competent to build safe Double Insulated equipment then a dual mono could perform electrically as two separated monoblocks. But we can't, so we are stuck with stereo, dual mono, or a pair of monoblocks. They all perform differently electrically.
What if I put two monoblocks inside one big enclosure? They'll still be monoblocks. What if I start taking out pieces from each monoblock original enclosure, at what point is the two monoblocks situation turned out to be dual mono?
F5 alive!
First music today....Gee wizz this thing sounds good!!!
As always I gots lots o questions to find answers for but I could use a little help for a couple...
1 Are the thermistors supposed to be touching the fets or just close by,,, say an 1/8 inch or so?
2 My xformer (antek 6218) starts to hum (not loud) every minute or so for about 30 seconds.. during this cycle,, mains V drops 1.5v and supply voltage drops a few tenths... also my supply voltage is lower than i expected at +- 22.5... and I can hear hum on the speaker faintly...
any thoughts?
thanks:D
This sounds typical of DC in the powerline. Use a bridge in the mainssupply, shorted +/-, and have a dipole capacitor over the unit (6.3 V/1.000 muF or s0).
This should block DC (up to 1,3 volt), toroids are very sensitive to that, get saturated sometimes at even 1 volt DC. They will then start to hum.
That explains the dropping of the output voltage.
imho this will also save on the power bill!
hope such a ting helps.
Power line conditioners of this type have been widely posted.
albert
Official Court Jester
Joined 2003
1 Are the thermistors supposed to be touching the fets or just close by,,, say an 1/8 inch or so? .......
to touch .
for excessive hum - you either have DC in mains , or xformer is bad - if everything is ok with rest of amp ;
but you say - it's working and making noises , so I resume it's good :clown:
PSU voltage is good
different routes for the return currents between the two channels. That's why I find it much easier to get quiet monoblocks. They cannot have different routes between channels when there is only one channel.
Just wanted to follow up on this and say thanks to Andrew for the tip about disconnecting one channel (I'll keep that one in mind for another time). Did some poking around in the amp and some resistance measurements and finally found that the cause of the hum was that I'd swapped input and GND cables on one channel :rolleyes:
The amp is now very silent in both channels and plays beautifully :D
/U.
albert
Thanks Albert ,,,I have began reading up on it....
to touch .
PSU voltage is good
Zen mod,, when you say ,,PSU voltage is good
do you mean my supply at 22.5v is good?
Just clarifying, thanks:)
any thoughts?
thanks:D
kewl heatsink fin idea!
how did you work out the attachment between the "fins" and the back plate?
_-_-bear
_-_-bear
Thanks Bear
The heatsink idea was not mine.. I got the idea from the Burning amp chassis that were given away at burning amp a while ago..
Each tube is attached using 2 screws from the inside of the tube into the back plate..
