Hello, I could use some help and advice on a rear loaded horn for the B&C 12PE32 driver. I am using Hornresp, and what I did was to use it for designing a hyp-ex horn in 1Pi space with the intention of folding it up and putting it into 0.5Pi space (in a corner). It is a 100Hz horn and I need it to go up to 500Hz. I've attached the input screen. In my limited research, I have found that according to this website:
Horn Theory
the throat chamber should be fairly large. He calls it a "coupling chamber", but it looks like a throat chamber to me. I found that in Hornresp the response gets better with really large throat chambers for rear loaded horns. The combined response doesn't look too good unless the path difference is large, like over 50cm. What kind of practical path difference should I choose? Anyone have advice on designing rear loaded horns?
Horn Theory
Make a frontloaded horn like klipsch la scala. See my avatarThe impulse response looks horrible though.... What to do?
See this topic.
http://www.diyaudio.com/forums/multi-way/182233-back-loaded-horns-7.html#post2458747
See this topic.
OK, have you found the La Scala style of horn to extend up to about 500Hz? I gave up on that when it was pointed out to me that it probably wouldn't, and that the folds would introduce a lot of dips and peaks in the SPL response curve. I suppose of course that a rear folded horn would also have a lot of irregularities in the response.
Have you designed La Scala type horns for other drivers?
I build a huge backloaded horn in 2010. The crossover around 200-400Hz from hornmouth to drivercone gave interference distortion what with to poor subbas was making me quit backloaded horn's. http://www.diyaudio.com/forums/multi-way/170024-project-presentation-horn-almighty.htmlOK, have you found the La Scala style of horn to extend up to about 500Hz? I gave up on that when it was pointed out to me that it probably wouldn't, and that the folds would introduce a lot of dips and peaks in the SPL response curve. I suppose of course that a rear folded horn would also have a lot of irregularities in the response.
I see this as a repeating problem for backloaded horns.
Better have a softer suspension driver that hornmouth response above 100-150Hz. So the 300Hz area stays smoother.
I made a small backloaded horn for my colleague who is still very pleased with it it uses a visaton w130s I designed a two way active loud speaker. It sounds remarkably deep for a horn and it is very tight for metal bass he plays often. It is not high efficient but still very loud played on volume with such a small driver.
http://www.visaton.de/en/chassis_zubehoer/tiefmittelton/w130s_8.html
The front loaded sm115 is beautiful because the horn cutoff above 500Hz also cuts of second and third harmonic above 500Hz
I agree with Helmuth - make a front horn. However I'd suggest making a straight horn. The likelihood of it working well will increase dramatically. For example, something like this:
Midbass Horns
Midbass Horns
Midbass Horns
Well, I had a long discussion in the Hornresp thread about his spreadsheet for designing tractrix horns. The upshot was that volvotreter's spreadsheet was incorrect for tractrix horns. His spreadsheet is fine for hyp-ex ones though.
A 100 Hz hyp-ex for this driver in 1/2 space is I think about a meter long, not including the back chamber.
I
OK, so back loaded horns are basically impossible to get right....
What is this "sm115" horn?
edit: never mind. The Beyma sm115 I assume is what you're talking about.
It is a way to have a more efficient loudspeaker not a way to get more high-ended sound. The horn loading helps to control the woofer movement.OK, so back loaded horns are basically impossible to get right....
beyma sm115
OK, so back to the front La Scala horn. Do you have any suggestions on how to fold up a straight horn to make it fit in the La Scala style enclosure? Also, I was told that a La Scala style horn with the parallel top and bottom boards would sound bad at the higher frequencies.
import the txt file of the sm115 in hornresp and change the driver parameters to your driver.Yeah, I've got those plans, but thanks. Those plans are for a different driver, not the one I have already.
OK, I'll give it a try. Thanks!
I'm looking at the tractrix horn again in volvotreter's spreadsheet. It sure does look attractive...
You could make a conical horn 65cm long that would hit 100Hz in 1/2 space with your driver.
I can't seem to duplicate that in Hornresp. The conical horn is still 1 meter long. How did you do it?
I would not do that you will be fooling your self you because it will not make a perfect fit with the corner. Calculate 1phi and hope you get that as result in the corner half-space.I can't seem to duplicate that in Hornresp. The conical horn is still 1 meter long. How did you do it?
- Help with Rear Loaded Horn Design
