Valve Itch phono
diyAudio Chief Moderator
Joined 2002
It is said that the Bias has unusual, low coils resistance for an MM. Something around 170 Ohm. I would use a 50K trimmer instead of an input load resistor. No extra capacitor than what the TT cables bring themselves. I would hunt with the trimmer for anything 2kOhm up for best balance. Its probable that you will soon agree that is a much more productive method for shaping MM/load curves, once you will try it. I wouldn't be surprised if its nicer around 8k-10k in the end. You can sub the trimmer for brown Dale anywhere you will settle.
No 12AX7 please. Possible grid leakage and other noises problems. Use the input tubes listed. They are dirt cheap to get anyway.
If you mean kinda vintage coloring cap, then maybe vitamin Q.
I'm collecting parts for the SSHV Mofet Shunt reg. for my Valve Itch. I still have some IRFP9240 from a previous project (Steve Bench phono). Can I use these in place of IRF9610 (Q1)? My regulator version will be that of the Evolution/Update link in the SSHV thread.
Many thanks and regards.
Joined 2002
Better not. Or use it until you get a 9610.
To go 380V will be dangerous for SSHV's reliability and will cause heat in the reg. Attempting it would need R5=5k6 in the reg link cct since MPSA94 is giving its max Vceo spec 400V at only 1mA. Also better is to sink the MPSA somehow.
Also 10mA is possible it will bring noise issues in the second stage. I would just drop in the 6N1P for 48dB gain at 300V B+ as in the standard Itch.
Referencing the heaters should be set for not exceeding all tubes heater to cathode max specs if B+ is to be changed.
Hi Salas,
Appreciate the advice, doesn't make sense to push the reg too hard or bump up distortion in 2nd stage.
To run 6n1p @ 150V, 7mA would I need to change R9 & R11 ? Even though it's supposed to be near replacement of 6h8c, it has very different plate curves at that op. pt. : ~ -2.3V versus 6h8c's ~ -4V.
This from data @ Tube Tester Files - 6N1P - 6H1?
At 300V B+ would you still recommend some sort of clip-on heatsink for the MPSA94 ?
Thanks,
Peter
Joined 2002
Make the 6N1P cathode resistors 330R so it runs at 100V across, 3mA, 1V cathode. The supply should be divided equally across tubes and 33k load.
Use the SSHV schematic as included in this thread in Fran's .xls with BOM. Since the MPSA is TO-92 and its going to get 210mW with 5K6 load, better put some makeshift fin or proper TO-92 hat on it, they fall fast from dissipation spec once in hot surroundings.
Joined 2002
Don't worry Dan, I received your payment & address.
Felipe
GB 1% RIAA caps Valve Itch closed I ordered & paid the caps, when arrives to Spain I will let you know.
OK guys, hope your 1% Riaa caps will arrive well. I took the GB posts out as discussed with Merlin so the thread cleans up after you concluded your mini GB.
I'm fixing to build one of these, this looks like a great project. I've built a few amplifiers but never studied a phono pre, so this is somewhat new territory for me. Exciting stuff. I really appreciate all the effort that's been put into this thread.
I wonder if someone could tell me what I would need to do to use a MM cart instead of MC. Is it as simple as just dropping the step up transformer and bringing the input as a voltage across R1?
Are you experienced with tubes projects in general?
Oh yes. I've built or repaired a number of amplifiers. I just finished one Monday night. My new amplifier is the reason I'm ready for a new phono pre. All of a sudden my existing phono pre sounds very inadequate. :)
