900W H-class PA Amp with Limiter
ALL EXPERT DIYERS PLS HELP.
I have two 40-0-40 transformers, so how i connect two transformers in series to work h900?
see the image.
pls draw and show.
thanks.
make sure you get the phasing correctly....
you can connect the secondaries in series as angel said.....
connect that to a low voltage ac source, say a 12 volts and then when paralleling the primaries, connect one side together, measure the voltage on the free ends, it should be zero, otherwise reverse the leads and then you can finalize the connections...
make sure to mark the ends of the leads so you know which goes to where...
is this method correct tony.
nazirdi,
you should be thankful to sir tony
see how this guy dig so deep regarding transformer
http://www.diyaudio.com/forums/power-supplies/191730-my-latest-traffo-build.html
primary phasing is important,sec phasing affect by pri
i remember how i deal with this before
some macrotech amp transformer(burned) my friend told me to repair,
i can no longer record any data it is filled with something like aspalt,if rewind you have to make new calculation and connection,so i end up something like your connection,parallel pri series sec.
same problem as yours,
i have a practical approach of using small copper wire as fuse during testing connection if there is something wrong small wire surely blow like fuse blow.
