Simple Symetrical Amplifier
Lazy & Fred.
The DUT is passing 100mA and has 4.9Vce when hFE=100.
This is a dissipation of 490mW. The junction will be changing temperature rather quickly.
Need to refine your "method" to help reduce the effect of different Tj on your results.
Hi Andrew ... a lot of Andrews are lurking in this thread :D
Look I know about the power dissipation in this case but (there's always some but) for a real comparison of power transistors you need to put them near bias collector current (100mA) conditions and compare them in that circumstances. The measurement has to be short one, 2 seconds max, just to read out the voltage value, afterwards voltage on 1 ohm resistor will of course rise up. But the first two seconds are relevant to get realistic comparison. One could even change Vce voltage from 4,9V to lower level with use of a zener in series with 1 ohm resistor but than BJT's Vce/Ic parameters wouldn't be in linear area of the graph any more - out of working point. So proposed measurement is OK, only it has to be performed for a short time. ;)
P.S. This measurement is not about absolute mA (hFE) values but relative ones between output power transistors to find as close matches as possible.
Hi fredlock ;)
You can use multimeter with hFE function which calculates hFE=Ic/Ib at Ic=1mA.
If you don't have such meter than you can use attached schematic. :)
Thanks Lazy Cat. I've seen some hFE matching circuit in the internet and also in the forum but just curious what you were using. I was thinking of building this project but I think your simple schematic would be good enough.
Testing hFE at constant Ic is a little more consistent than using constant Ib.
I always use constant Ic now, for hFE measurement even though I don't know Tj.
Multimeters, with a give away for free hFE tester built in, generally use constant Ib.
They are no better than a batching tool. The problem is that one does not know what Ic is.
Could you share us you hFE matching circuit then? Which might benefit me and the others to match it perfectly.
Thanks for the explanation LC............
+10
Thank-you. I will try to answer your question on my thread, it looks like this does not interest L.C. at all.
Hehe don't worry I looked at yours Crescendo modification to CFB and I must say I'm impressed. I saw you have very small Ic in input pair, is that OK, cause usually input transistors should work at 1-5mA collector current. That also means smaller influence of parasitic capacitances if the collector current is larger, which finally brings you wider bandwidth and higher slew-rate, all though I saw yours sim already shows 380V/us. :eek:
Please continue thread in solid state part of the forum I think it will bring more interest from enthusiastic amp builders. ;)
Yes, this circuit test a transistor at constant collector current level you choose with SW combinations, but the same temperature dependency appears here, base current will go down with temperature rising, so matching is again time dependent. For simplicity and relative only comparisons sake I suggest you to built simpler one. ;)
Multimeters usually have fixed Ic to 1mA, but that is usually not accurate enough for comparison between power transistors.
hFE measurement at Ic=100mA is just a fine compromise between accuracy and power dissipation vs. temperature dependency.
At mine proposed NPN/PNP measuring schematic no formula calculations are necessary, mV reading is actually hFE data. ;)
Dear Mr. Andrej
:worship: Thank You very much for the most beautiful SSA-V12 version. :worship:
You make me the beautiest day since long time awaiting for something to drive my speakers civilized - and You make it. :cheers:
I know, this is the most Generous Scorpio's gift, You give to the whole worldwide sound-lovers & audio community. Thank You ... :worship:
:worship: Long Live & let God :hbeat: bless You . . :worship:
Andreas
Thank you Andreas :)
I couldn't even think the SSA Balanced V-12 schematic would make you so happy, I'm really glad it did. :cheers:
I realize XLR-RCA input connection should also be explained, so here it is. ;)
Thank-you, on that mod, I wanted to propose as less modifications of original values as possible. But you are right, will see if any improvement in increasing the current in the input trans, witch was supposed to be 0.2 ma in the original schematic, very good sounding, in fact. A way too to reduce the values of feedback resistances as you like.;-)
You only can be impressed by yourself, it is just your idea !
I'm more interested to have your opinion and expert suggestions on my differential protection circuit idea.
http://www.diyaudio.com/forums/digi...sures-class-d-system-project.html#post2731810
If you like-it, i would be very happy to see-it added to you nice SSAs.
I'm working on an integrated solution: Remote power-on of the amp from the 12v preamp rail, soft power with a current limited delay of 2 sec to take care of the power caps and switch on the Loudspeakers after 4 more seconds or so with this "protect against everything" instant reactive circuit.
I will not leave your thread for no price, i just do not want to bore-you with less noise as possible :).
As i said, you deserve my sympathy for your passion, generosity and brilliant expertise, makes-me remember when i was young, so many years ago ;-)
Thanks LC for your straight forward answer and brilliant advise. Appreciate it. :cheers:
The most difficult Speakers for all amplifiers on the globe
Esperado,
Apogee Scintilla . . .
Theirs sound is so unique that no conventional speakers come even close. :rolleyes:
They require an amp with constant ability drive 0.5 ohm all the time.
Impedance is almost flat line and never leave 0.9 ohm.
The sound, .... incomparable with anything You hear till today - Unique.
They require a nice, civilized arc-welder to drive them, but for return
the listener is constantly in heaven :headshot:
Andreas
but for return the listener is constantly in heaven
I believed Hifi was dead ! You use ribbons, i use spherical horns, we gone kick the *** of the smartphone's sound ! Did-you tried some good Class D amp for the basses with your crazy speakers ? They love low impedance. Of course, for treble, SSA would sound gorgeous, i presume.
Ps: my impedance line is quite flat too, between 5.9 and 6.5 ohms all the way, that's one of the secrets ;-)
