Metal Film or Carbon Film Resistors in Marcof PPA-1h ??
Here is a picture of some resistors on this 1979 vintage moving coil head amp from Marcof. Do you think these are carbon film or metal film design? Since this is a high gain (34 dB), very low signal device, I was thinking it could benefit from a lower noise resistor. Noise here is further amplified by the phono section amp, then the pre-amp, and finally the power amp. Metal foil would seem to be the best but is not available in correct values, and metal film would appear to be the next best choice.
I'm thinking the beige body color and the vintage would suggest carbon film??
Thanks for the quick responses. On a check it appears 1% carbon film resistors are now about as common as hen's teeth. Anyone know if it was the same 30 years ago? If so along with the other clues it would seem virtually 100% certain these are metal film. Thought there might have been a cheap upgrade to reduce noise, but it appears not.
Change the loading resistor to a dale RN65 type. That will be an improvement.
By the loading resistor do you mean the loading resistor for the amp (R7 in the circuit drawing at the link below)? Or the loading resistor for the moving coil (R1)?
Marcof PPA-1h Circuit Drawing
Yes, there appears to be differences in the types of metal films. See the figures near the end of the article below. However, finding the good ones in small quantities seems to be another matter. Sources for the RN65? Is that just a military designation for the Dale CMF?
Resistor Current Noise Measurements
I'm thinking of using the Welwyn RC55 metal film? They seem to test fairly well. See figures 7 & 11 in this document. Need to convince myself they are OK in 1/4 watt as that is all I can get. The Vishay Dale CMF come in 1/2 watt, but don't seem to test as well... Can also get some Yageo, but in poorer qualities than those tested. And the ones tested were poor.
The Dale's are stock at Mouser. The military version in 25 PPM tests well by measurement and listening equal to the bulk metal Vishay's at a much lower price. Use it as a cartridge load resistor and get a few values to see which one you like best.
See Linear Audio Vol 1 for details.
