Monaural Pre-Amplifier like X0.2/XP-30 so as Integrated Amp - very special and rare
Monaural power amp devices are nothing special - there are a wide range of manufacturers.
But for me very special are pre-amplifiers and integrated amplifiers in a monaural design.
And such design's I prefer
Unfortunately I know only this examples from each kind of amp.
1) Monaural Pre-amplifier: only the currently available Pass XP30
Pass Laboratories
http://www.passlabs.com/pdfs/product manuals/XP-30_OM.pdf (Owner's Manual english)
and the legacy (vintage) model X0.2
http://www.passlabs.com/pdfs/old product manuals/x0.2_om.pdf (Owner's Manual)
DONG FONG AUDIO: Pass Labs X 0.2 PreAmp ( Used ) (Offer)
2) Monaural integrated Amplifier JVC AX-M9000
HiFi-Do McIntosh/JBL/audio-technica/Jeff Rowland/Accuphase
http://venetor-sound.com/main/AX-M9000-01.jpg
http://venetor-sound.com/main/AX-M9000-02.jpg
VICTOR ƒ‚ƒmƒ‰ƒ‹ƒvƒŠƒ�ƒCƒ“ƒAƒ“ƒvAX-M9000‚ÌŽd—l ƒrƒNƒ^�[
??????????????????AX-M9000??????????????RM-RE9000?
http://av.watch.impress.co.jp/docs/20060914/vic15.jpg
http://www.jvc.de/html/faq/highend/ax-m/2142/AX-M9000Deutsch.pdf (Owner's German)
JVC AX-M9000 Manuals, Support and Troubleshooting - Amps (Owner's english)
JVC AXM9000 Service Manual free download,schematics,datasheets,eeprom bins,pcb,repair info for test equipment and electronics
JVC AX-M9000 SM 2 Service Manual free download, schematics, eeprom, repair info for electronics
The preamp models X02 and XP30 are more consequently aligned to high performance, because the power supply has been extracted along with the operating/VF-display unit (with a lot of devices, which are critical by a close arrangement of the signal path) of the actual pre-amplifier devices.
This wasn't realized by the integrated Amp from JVC.
Who knows additional examples of this very rare genre ??
For this reason it would be a good idea, to replace the presently output stage through a very small power amp stage in your preamplifier for a special integrated amp series (e. g. arround 2-6 watts output power at 8 ohms) for directly connecting of high efficiency speakers (or also even low efficiency and small speakers like ProAc Tablette or Auratone 5C in very small rooms).
The already massive housing envelope is entirely sufficient as a heat sink by this wattages.
In your currently monaural preamp models unfortunately this massive aluminum housing parts are not used as a heat sink.
The AMR AM-77 is a Stereo Amplifier, however it can be switched to mono operation and multiple units can be slaved together. So it kind of applies.
In Mono-Mode the solid state output stages of the two channels (it is a hybrid amp) are paralleled up on the inputs (and also outputs too if the single output mode is selected - bi-amping is the other option in which case the outputs remain independent), everything else just uses the left channel's circuitry.
Ciao T
Preamplifier : Signature 6 (total of 6 cases) , Signature 4 (4 cases, phono stage built in the L+R preamp boxes)
For each channel of the six box affair : 1 power supply chassis, 1 preamp case, 1 phono box.
(Signature power amp : 1-case stereo version, 2 monaurals, and a 4-box version with 4 x 500VA transformers per channel)
YBA Signature - various versions of pre-amplifiers and power supplies (no internal images of screening and closed line modules to find online).
