Odd regulator for frontend
In this schematic for an amp, I found that the 40vac is fed through a capacitor before the rectifier. Is there any specific reason for this type of design.
Gajanan Phadte
The conventional rectifier gives ~ 55Vdc to 60Vdc at the smoothing capacitor when under load.
The voltage doubler rectifier gives ~110Vdc to 120Vdc at the smoothing capacitor. NO IT DOES NOT !!!.
The doubler is more likely to give 90Vdc to 120Vdc at the smoothing capacitor when under load.
The circuitry after the doubler must be designed to take account of the wide variation of supplied voltage and also designed to reduce the very much higher ripple voltage on the supply.
The regulator (actually capacitance multiplier) is the designer's way of trying to ameliorate that big variation in supply voltage.
Can someone check the required voltage ratings of capacitors C6, C8, C19 & C21?
I would recommend a separate voltage regulator be fitted after the capacitance multiplier to give the front end voltage you require.
This voltage regulator could simply be a Zener or a transistor assisted Zener.
