A Thread for those interested in PPSL enclosures
check my dimensions for this PPSL i'd like to build. i currently have 4 peavey SP118X cabinets loaded 1808 SPS BWX drivers and would like to build 2 dual 18 cabinets. the box is about 10 cu/ft with out bracing. port is 4W x 21.5L x 10D.
Scameron,
21.5 x 23 x 42 are all dimensions that are not multiples of any truck box I am aware of.
What is the rational behind those dimensions?
DJK's 32x24x24 dimensions will work for wide body semis, but I'd suggest going with integers of the usual 90 inch clear box width and height of rental trucks.
Those integers would be 11.25, 15, 22.5, 30, 45.
Mixing in some integers of 98 allows for a decent truck pack in either wide body semis or regular straight trucks.
Making something that only fits a specific van or car pretty much insures a "fire sale" if you change vehicles or decide on different cabinets.
Art
Hi badman,
Putting the passive radiators into the same plenum (manifold) will increase the volume of the plenum a lot, and this may reduce the effective coupling of the drivers, which is what you're really after with the PPSL.
I would keep the passives out of the front plenum, and go with djk's recommendation of keeping the plenum small. This should help in reducing the upper frequency response peak (see: Post #5 and #6).
Thanks for your input- the increased volume of the plenum should not be an issue for coupling, in my understanding- what it WILL do is reduce any downward Fs shift due to mass loading. The coupling has to do with spacing, which will still be close together. I'm not talking about making it wider, just giving a taller height.
Peavey 1808 SPS BWX
Specifications: • 18" woofer • Impedance: 8 ohms • Power capacity: 2000 watts peak, 1000 watts program, 500 watts continuous • Sensitivity: 97.5 dB; 1W/1m • Usable freq. range: 35 Hz - 1 kHz • Cone: Kevlar® impregnated cellulose • Voice coil diameter: 4.0" / 100 mm • Voice coil material: Aluminum ribbon wire Polyimide-impregnated fiberglass former Nomex® stiffener Solderless diffusion welded OFHC copper leads • Znom: 8 ohms • Revc: 6.71 ohms • Sd: 0.1237 sq. m • BL: 16.26 T/M • Fo: 37.4 Hz • Vas: 368.0 L • Cms: 169.4 uM/N • Mms: 106.7 gm • Qms: 7.545 • Qes: 0.637 • Qts: 0.587 • Xmax: 4.60 mm • Le: 0.38 mH • SPL: 96.7 1W/1m • No: 2.94% • Vd: 69.4 cu. in./ 1138 mL • Pmax: 1000 watts pgm • Disp: 228 cu. in./3737 mL.
Put the drivers back in the SP118X cabinets and sell them. Buy better drivers, then build a box for them. I don't care for several details of your design, but when you find some better drivers we can try again.
Note:
The Eminence 15 can displace more volume than that Peavy 18, and the box will have flat frequency response. The T/S parameters are not very good on the Peavey.
i see. i don't recall asking about how bad my drivers are; i understand they are not the greatest. i only wanted to place them in another box so i could maneuver 2 boxes instead of 4. i've beat on these speakers extremely hard in 9 cuft boxes for several years. according to simulations in bassbox they reach xmax with very minimal wattage; they should have died by now. individuals come to this site for information. i thought i would try to design something based off what i have read in this thread. i must be completely off base. selling the peaveys is not an option right now seeing how they are used weekly. when the money is there again, i will buy new drivers. till then, i guess i should keep educating myself.
ahahaha. i guess so.
it's about what works for an individual.
Indeed it is. Your drivers would require a HUGE box to perform well, due to the high Qts- they'd be better off in a large, sealed enclosure, IMO, than a tuned system. Try modeling it with WinISD, you'll find what different arrangements require and look like.
My own "PPSL" styled sub is very different from what is discussed in this thread, being passive-radiator based and those living inside the manifold (though I am still considering whether to try to mount them outside the plenum)
Exceeding Xmax does not kill drivers, exceeding Xlim will.
Many driver's suspension are so tight that they can take a boatload of power after exceeding Xmax but before hitting Xlim.
Though the drivers will distort like a pig at that power, they will not die until burnt to a crisp.
From the minimal PP testing I have done, (only on Lab 12s) it does not appear PP will eliminate much distortion (THD, the even orders may go down while odd orders go up) when a speaker is driven past Xmax.
PP with a plenum will sound different than your present cabinet, but may sound no better, and even worse, if you push them past Xmax.
Art Welter
My experience, and that of Les Hudson, show that it does indeed reduce distortion even when overdriven.
However, when the amplifier clips, the sound changes quite a bit. I have not had a problem with this on live music, but on dance music it can be heard on long sustained notes (the clipping adds a bunch of 3rd and 5th).
I tell people to give themself a while to get used to the different sound, because they do sound different. So far only one person has flipped the backwards facing woofer back to the 'normal' way, he really liked the sound that way (really 'thick' sounding).
I encourage people to try it and see if they like it. If they don't, they can always flip the one woofer back and it sounds a lot like an EV MTL manifold box (a personal ugg for me).
I would phrase this differently, because I think that statement gives the reader a false impression that misrepresents the usefulness of this configuration.
Push-pull drive substantially reduces even-harmonics (2nd, 4th, etc). The amount of the reduction is dependant on the distance between sound sources and the frequency range used. It tends to work best at low frequencies where the sound sources are acoustically close. In a push-pull subwoofer, it is not unrealistic to obtain 1000-fold reduction of even harmonics, basically eliminating them altogether.
If another mechanism is also used to reduce odd-harmonics (3rd, 5th, etc), then you can achieve excellent results. I believe the design philosophy of the slot-loaded push-pull configuration is to use a front chamber to reduce higher harmonics. How much this dips into the third, I don't know. I would expect it depends on the drivers and chamber size and dimensions. One can also choose driver that had reduced odd-harmonics to begin with. This would imply that it tends to have symmetrical nonlinearities as opposed to asymmetrical asymmetries.
As for what happens when you go past Xmax, I think probably the answer is to avoid that. Use the driver within its limits for best results. I mean, you're fighting against yourself when you push the driver too hard. The distortion mechanisms will still work, but they'll be working against skyrocketing distortion. Then again, I guess that's when the system needs the most help.
Conceptualizing a different style
Using some of the concepts of PPSL, I'm looking at doing a dual passive radiator setup. What is proposed is 2 standalone subwoofer enclosures with passive radiators, one with frames inside the cab, one with frames outside (push pull). These two independent cabs are then joined together with a U-shaped frame with holes, bridging the gap between the cabinets, and are firmly affixed to the original cabinets with screws/bolts/whatever.
The holes should allow plenty of surface area and breathing room for both the PRs and the drivers, but still act as something of a lowpass filter, while gaining some even order distortion cancellation from the "push pull" mounting. Additionally, the U-shaped frame could be lined with felt or some such for some additional absorbtion of higher frequency harmonic components.
While the manifold PPSL design has an advantage in better mechanical coupling/force cancellation, this design has one big advantage- it's easy to retrofit to existing subwoofers, and can be divided up for ease of transportation or for those times when you want 2 smaller subs instead of one manifold monster. There would be some directionality effects at higher frequencies, but I don't think they're relevant to discussion as both PPSL and this concept are "pure sub" designs, and not really meant for >150Hz operation.
Attached is a concept pic, 2 cabs next to each other with a U-frame to bridge the gap.
Just finishing up.
Wisconsin had a bad storm last week and the power was out a couple of days at my brother's house. With cleanup and emergency roof repairs it put things back a bit.
Yikes, sorry to hear that - I hope the repaires weren't too bad!
Good luck with the rest of the PPSL build. When you have a few minutes, can you let me know about flipping your design 90 degrees and what changes to it would be necessary to accomdate this?
Thanks,
Jim
djk, the whole cabinet rotated 90 degrees as shown in your second pic vs. your first pic. I just need something that is taller than it is wide and rotating your entire cabinet design 90 degrees accomplishes this.
Not sure how the plans would change other than adding the brace in the port.
Thanks,
Jim
The brace in the port is in both photos, it runs down the side, across the back and up to the front on the other side.
With higher Vas drivers (like 18s) you can make a cabinet 48" tall, about 24" wide, and about 24" deep. That gives a good stacking height for mid-high boxes. The ones in the linked photos are W36xD30xH24, and so they can be either 36" tall or 48" (a stacked pair).
